slotted rotors question
Originally posted by DaveGS4
Hmmm, never heard of cutting rotors? What's that?
i guess you could call it resurfacing
you know when you put it on the brake lathe and it "cuts" into the rotor
i never had slotted ..drilled rotors before so i dont know what you would if you had a pulsation
in the brake pedal
i dont have this problem yet but i was wondering if this problem did arise are you able to "cut" or do i have to get new rotors
Ammco Rotor Only Brake Lathe
Yes you can have them resurfaced, just have to have one of the newer pieces of equipment to do it (lathe?). I've had my drilled / slotted rotors resurfaced at the Lexus dealer here in town.
Originally posted by DVSG3
Typically, how many times can you resurface a rotor before it is no longer safe to use?
use a rotor measurer (dont remember the real name of the tool)
but it measures the thickness and then you know whether you can "cut "or have to replace
