OK, how do you adjust the Tein CS coilovers if you do not
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
A little allen key comes with your coils..From the factory your coils are set to the hardest setting(turned all the way clockwise, 16 clicks total) and after the initial install you simply turn counter clockwise, 1 click at a time.You should start by turning both front and back 10 clicks and then continue fine tuning your suspension from there...Rule of thumb is, clockwise is stiffer and counter clockwise is softer..-VERY IMPORTANT-Listen for the clicks and DO NOT continue turning if you dont hear a click!!!! If you don't hear a click then you either have it fully turned or if you don't then simply turn it back one click and then continue in the direction that you were turning..Hope this helps and good luck...
Note EDFC or coilover top adjustments is only for damper stiffness, and has nothing to do with height setting which requires the wheels to come off with or without EDFC.
Originally posted by DGOT20s
Is ClubLexus the BEST or what?
![Big OK](https://www.clublexus.com/forums/images/smilies/bigok.gif)
