View Poll Results: which one?
supra
38.46%
rotora
34.62%
neither
11.54%
stock (oem)
15.38%
Voters: 26. You may not vote on this poll
Supra Vs Rotora
Originally posted by alexus
how much did you pay for your "supra big upgrade kit" ?
Northern California Regional Officer
Ryan23 and others on IS300 .net have sold new calipers for $375 a pair.
Drilled and Slotted rotors are $169- 203 on E-Bay or Tirerack
EBC Brake pads $80 on Tire Rack
SS Brake lines around $130 from Steve @ Carson
There's also used TT brakes always on sale on supraforums.com
btw
for LEXUS GS400 98-03
what size is for rotors?
330x 30 or 32?
they also have
355.. but i guess they dont fit lexus gs400 98-03 right?
thanks
btw
330x 30 or 32?
they also have
thanks
The 30 or 32 doesn't affect the wheel clearance.
The 355 can be used with 19 in rims and larger.
With all these big brakes, the rim spoke / center design affects whether the caliper will clear the wheel. You cannot depend on diameter and offset alone to know if it will fit. Get the wheel template from Rotora and use it to check if your wheel will clear. I think it is posted on their website.
alexus,
Unless you've just raised your budget even more, you are looking at the 330s. Just make sure the calipers will clear your wheel.
i have 20" and last winter i took 'em off and i put 18"
also, can someone suggest a good place to buy them from? I found different range of prices for same rotors 330x32 $1300-$2100, most of them are $1700
i also want to get rear one too.. that's another $1k wow they comes out to be expensive.. but i still want to get 'em
yes we talking about rotora..
so wait a minute..
if i let's say put 4 piston front, i can not really put 4 piston rear?
and what do people have at rear who purchased 4 piston on the front?
so wait a minute..
so wait a minute..
so wait a minute..
If you want a 4 front/ 4 rear combination there are several considerations:
1. Rotora does not market a 4/4 system yet.
2. Stop Tech does offer a 4/4 now, but you have to buy the whole front and rear package at once because the Front ONLY brake kit IS NOT compatible with the 4/ 4 system. What I am trying to say is you can't buy the front 4 piston now and then add the rear later. Rotora may do something different and allow the rear set up to be added on, but that feature is currently TBD.
3. Brake systems must be balanced. You would never buy a front sway bar ONLY and then add a rear sway bar. That would be very dangerous to drive. This is the same scenario for upgrading brakes.
4. The StopTech 4 / 4 and Rotora 6 / 4 are high dollar brake systems, so unless you've upped your budget, they are probably not on your list of options.
On a different Note: We generally talk about Supra TT brakes being heavier than other BBK kits, which is generally true for Brembo, AP, StopTech and Rotora. One thing not to loose track of is that (as Neo pointed out) Rotora offers 1 piece or 2 piece rotors.
So when comparing the Supra TT vs Rotora for value and performance keep in mind the following:
1. The 1 piece rotors weigh a ton. Though the Rotora calipers will weigh a little less than the Supra, it's the rotors that make a big weight difference. I would be very curious to know the weight of the 1 piece Rotora rotors are. I'm sure someone more knowledgeable than me will chime in on that one. I would guess that the overall weight advantage of the Rotora vs. the Supra will be negligible, when using the 1 piece rotor set up.
2. The 2 piece rotors weigh a lot less, but at a higher cost, which makes the entry level Rotora set up much more expensive than the Supra.
so wait a minute..
so wait a minute..
Most people just upgrade the look and feel of the rears, i.e. drilled and/or slotted rotors to match the fronts, SS lines, better pads,...
On another front, LXOGOOD is working with Rotora on something for the rear that supposedly works with the fronts (since he is sponsored by them and he has the front 4-piston kit). I don't know what this is but I assume he will announce something when things are ready.
wow.. i dont think it makes sense for me upgrading front and not doing anything to the back.. or puting diffirent brand at the back..
so maybe i should think about supra big brake kit after all..
how much is supra bkk cost for front and rear? anyone have any ideas?
Another option is DSR which are basically the LS monoblock brakes. They are currently working on getting the right adapters for the rear LS brakes to fit on the GS.
4 wheel brake upgrade is not necessary since the fronts do 80% of the work. If money's no object though go for it.
I have 355mm (14") StopTech fronts on my car and they're great. I'm sure the Rotaras are really great too. Even though Supra brakes might be cheaper, I suspect the calipers (and rotors) are a good bit heavier plus the Supra calipers are insanely huge and probably require more in/out clearance than any other brake setup.
One warning if you go with 355 size brakes - good luck finding a spare rim to fit!
