Brakes Shudder When Wet
well, when the brakes are warm and dry they work perfectly, but after i wash my car and the brakes are cold, they shudder very badly. it shakes the whole car and makes alot of noise. i notice this when it rains and the brakes are cold also, but when they warm up its all good. anbody ever expierence this or hear of it? anybody know what causes this?
It's water between the pads and rotors -- my SC400 got really bad after a wash when it needed new pads and rotors.
My current SC300 w/ 12,000 miles since the last brake job does this too -- in Drivers Ed. they teach you that when your brakes are wet you need to step on the gas and brake at the same time while going about 20 MPH -- I think this is nothing more than that. If it really bothers you, maybe you should check your pad and rotor wear, if you don't know how, take it to a friend or mechanic who does (it's not hard stuff)
JT
JT
Mortgage Slave
That seems right (about the water). After most washes and if (accidentally) driven through puddles of water my brakes get like that... about 5 min lightly pressing the brake and still on the gas (slow speeds) dries them out.
The One
Do you also see some rust on the rotors? I know I get that but after driving for a block or so with a few intentional stops, the pad/rotor contact will wear away the rust and things are fine again. This happens to many on here (since the topic on the rust has been raised before) so it seems to be normal.
The One
Originally posted by 97SC300
yeah there was alittle rust on the rotor, is there any way to prevent this from happening? I've never had rotors rust instantly when i wash my car.
damn that sucks, its a shame such a nice car has this kind of problem. its pretty embarrasing when my neighbors hear that horrible sound after i wash my car and move it like 10 feet to the garage to dry it.
maby changing to a different kind of brake pad will do the trick?
happens all the time when I wash the car I've learned to ignore it.... What I do is just go really slow and then hit the breaks hard. I do this a few times and it goes back to normal.
I get it too, after EVERY car wash...and I wash my car underground so there's zero sunlight to dry it out. I just drive the car around the block a couple of times and then finish the job with a chamois.
i get it if it rains at work for a long period of time...or if i leave the car out in the rain anywhere...
CEO
