ABS issues...please help!
Ok I have finally finished the drivetrain, I swaped a 2jz-gte with the 6sp and maching TT rear end. I first upgraded to TT brakes in the front and after the 6 sp swap that I finished about 2 weeks ago I swaped in the rear TT brakes. At 70+ mhp on my ABS light turns on. I had the rotors turned becuse I was feeling a bit of vibration at high speed light braking.
Now there is no vibration but I still get a ABS light at 70 or higher without tapping on the brake. It turns off when you turn off the ignition and only comes on when your at highway speeds. I think that its the ABS sensor but how can I check this? The rear brakes are used, I may want to do a rebuild on them. I did not get this problem with just the fronts though. If any you guy have ideas or what not let me know cause this is getting annoying everytime I get on the high way.
I am about to swap in the Daizen bushings, sways and TEIN FLEX kit coilovers but I want to take care of this issue first . Let me know any suggestions, because the sensors are around $150 a piece and I figure I should change them both if I have to but I would rather not if its not the root of the problem, and spend the money on something that would make more power.
Thanks and let me know
Adriel Gonzalez
P.S. Sorry for the long Tread.
Adriel Gonzalez
