Brake pad replacement maintenance tip
Old 07-14-04, 09:20 AM
hansjl
hansjl's Avatar
Default Brake pad replacement maintenance tip
When you get or do a brake pad replacement or remove your calipers for any reason on your GS, or any other model for that fact, try puting some anti-seize on the sliders to avoid them freezing. Sure wished my Toyota dealer had when he did my front brake job. The seized slider caused the out pad to eat into the newly surfaced rotor. I'm lucky that they were able to loosen the one slider and free it.
Just a thought and a cheap and quick bit of insurance..........
Old 07-14-04, 11:52 AM
engin_ear
Everything in Moderation
engin_ear's Avatar
Interesting...I got the same tip from a local Toyota dealer in NJ about a month ago. I wound up using the Permatex Anti-Seize compound that is available from PepBoys. It doesn't like to wash off very easily, so I figure it will hang around on the sliding parts longer than anything else. I also used some of the CRC Disc Brake Grease in places, also avail at PepBoys. You just have to watch that you don't get any of this stuff on the pads, or places that will squeeze out onto the pads, or you'll be in for a bit of a ride....
Old 07-14-04, 01:28 PM
ntran18
ntran18's Avatar
Which part are you referring to?
File Type: pdf
Old 07-14-04, 01:33 PM
engin_ear
engin_ear's Avatar
For front calipers, the pad support plates (clips). The pads slide in/out on these support plates.
For rear calipers, the sliding pin that goes thru the hole in each pad.
10lexISR6
RC - 1st Gen (2015-present)
06-25-18 08:46 PM
schan1w
Maintenance
11-05-09 03:12 PM
sickntired
04-13-08 04:14 PM
hansjl
Suspension and Brakes
07-14-04 06:37 PM
Quick Reply: Brake pad replacement maintenance tip
