TRD Upper Front STB Help!!
I just installed a TRD Upper Front STB in my GS300 and the problem I've come to is that the bar is touching the top part of the engine so after a while it's melting the hose and making a big vibration which makes the whole car shake at idle or low rpm. Anyone who knows what I could do to fix this please help!!!!!
Thanks!
Thanks!
O-ring brackets did help to raise about 3-5mm, but not enough. Only way I can think of next is to grind the TRD sway or raise it more with additional brackets.... ??? Not too sure yet, but.......
Stef
Stef
Originally posted by 92 sc three
FYI, the TRD bar wasn't designed to fit the 300
GS300 engine sits taller than the V8. You might try more spacers to raise it up - don't know if it will work though. I'm surprised it touches the engine. Is it hitting the engine itself, or just the engine cover? If it's just the cover, take it off.
The One
Originally posted by Stef
Great... But the engine bay is pretty similar no? I was told that it would fit plus it came off a gs4.
