Another LS 400 Brake Conversion Completed
03-26-05, 10:38 AM
O.C. Lucky Strike Fanatic
Looks hot man!! What kind of gold paint did you use? High temp gold paint or just caliper paint? thx
03-26-05, 12:15 PM
Quote:
Originally Posted by TurboTeg
will the rear ls400 brakes bolt on as well?
They will, BUT there is no point. The rear LS400 calipers are the same ones on your car now. If you are looking for 2-pot rears go with the TT brakes.
03-26-05, 09:27 PM
03-27-05, 02:47 AM
Which brake calipers are better? Supra TT or LS400/430?
03-27-05, 10:55 AM
Quote:
supra........
06-01-05, 11:23 PM
can't wait to get mines!!!!
06-03-05, 11:23 PM
how much heavier are the supra calipers?
06-06-05, 12:31 PM
That weight amount is negligible. Why?
06-06-05, 04:57 PM
I'm just curious what the weight difference is. If it's negligible like you say, than I guess it doesn't matter...
06-06-05, 05:06 PM
What Brand Drilled/Slotted Rotors are thoes in the pics ?
06-06-05, 05:24 PM
The rotors i think are from rotorworks. They are cross drilled/slotted and zinc plated.
06-06-05, 05:28 PM
I have driven both the Supra with the TT brakes and the SC with the LS brake conversion and i can say the front brakes are relatively the same, the Supra brakes bite harder , only due to the two piston rear calipers. It is definitely a noticeable difference from the stock calipers.
06-07-05, 10:08 AM
Yeah man, it's not an amount that matters. It wouldn't be a weight-savings issue worth worrying about...
Bradster
04-23-10 10:58 AM
JesLet
Suspension and Brakes
01-21-08 12:20 PM
BigWaveSC
04-19-06 05:21 PM
JSC300
10-19-05 02:05 PM
tvd51
04-24-03 09:22 AM
1991 ,
1993 ,
300 ,
400 ,
97 ,
brake ,
conversion ,
fit ,
is300 ,
ls ,
ls400 ,
rear ,
sc ,
sc300 ,
shock
