difference between trd and supra brake upgrade?
Re: warning also....
Originally posted by gewe21
I might not be a reliable source for this, but.... it's worth considering.
If I remember correctly, the Supra TT setup fits the 17" stock GS wheels, or maybe with only little mods (thin spacer). I have an LS430 and those front caliper are huuuge and quite a royal pain in terms of rims fitment, or so I heard. Again, please reconfirm this.
Originally posted by gompka
Yikes those things are monsters.... what size rims are required for those to clear?
Originally posted by HKGS300
At least 18"
At least 18"
also keep in mind guys. the supra tt brakes is a direct swap on the GS. however the ls430 calipers do NOT fit directly over the GS. i am very sure about that coz' testing has been done before. they will NOT fit. you need special brackets to made, which brings up the question of quality, strength, heat, etc...
Jeez, Henry, on a roll aren't we???...... 5 replies in one shot. You could just consolidate them you know.....
Anyway, the DSR brackets are made using Nickel Cadmium alloy which is the same material used for race cars brackets. The strength of the material is very good and I have been very pleased so far with the quality. My DSR kit can be had for a shade unde US$2,000 I believe.
But, yes, Henry is right. You don't need 18s to fit them. What you need are lower offset (mine's +36) and a high disk setup and I have enough clearance to be comfortable and not rubbing at all. I believe even stock LS430 wheels are also only 17s?
Hope this helps. Cheers.
http://night-pager.com/
But they can be expensive..
and there is a good difference in weight between the Ls430 calipers and the TT set-up..
This web site has more info on this..
Originally posted by johnee78
I thought I was the only one who noticed.. No wonder he does about 50 posts a day..
umm.... ok, honestly, if the dsr setup goes for 2000, i think it's probably on the high side considering what you get
Originally posted by tinygs
True, there are MANY SupraTT owners who, even after upgrading turbos, fuel system etc. still have confidence enough in the stock SupraTT brakes to leave them on the car. IMO, Its the most cost effective, "bang for the buck" brake upgrade for the second gen GS. The ease of installation due to it being a direct swap was one of the major selling points for me.
Ow, you mean these baby???? My UCF30 (LS430 monoblock) conversion with DSR brackets cost me a pretty penny, but it's sure a nice upgrade from my old TRD setup. I think besides me, there's no one else who has gone from stock, to TRD (supra), to UCF30 (monoblock). The difference from each stage is quite significant. I highly recommend it.
If you are interested in the DSR monoblock kit, please pm HKGS300. Cheers!
Originally posted by lexusondubs
do these stop better than the TRD and the TT setup ??? and with the caliper and the bracket what was the cost ???
those dsr, you should talk to steve ganz, he's the only one who can get you those stuff
