Tire size recommendations?
Old 08-22-04, 10:22 PM
DaJark
DaJark's Avatar
Default Tire size recommendations?
20x9 38 offset fit on gs 300? Will 255 35 20 fit without rubbing?
Old 08-23-04, 03:28 AM
rominl
exclusive matchup
rominl's Avatar
Default Re: Tire size recommendations?
it will rub pretty bad. even with 245 you will need some work done
Old 08-24-04, 02:17 AM
lexusondubs
dubsonlexus
lexusondubs's Avatar
Default Re: Re: Tire size recommendations?
rom i dont think that is correct i have a 20x9 with a +38 offset in front and no rubbing at all
Old 08-25-04, 01:42 AM
rominl
exclusive matchup
rominl's Avatar
Default Re: Re: Re: Tire size recommendations?
well the problem is 255. that's a good 10mm wider and i kinda worry about the effect on that
i have 20x8.5 +32, which is the same as 20x9 +38, with 245/35. i lowered to 1/2 finger. and without the fender mod i did, both, i would be rubbing every min
rominl
exclusive matchup
rominl's Avatar
oh sorry to say, of course, as usual, also depends on what brand of tires you use
Old 08-25-04, 04:07 AM
lexusondubs
dubsonlexus
rom but to all fairness you slammed your car and did not just "drop it"
Old 08-25-04, 07:34 AM
bluelex
bluelex's Avatar
definately go with a 245/35/20 if u can. 255 will rub and brand does matter. some r rounder edges and some r square..
Old 08-25-04, 11:10 AM
TTurboPimp
TTurboPimp's Avatar
I agree with Blue Lex....
I have had both sizes, 245 &255, on a 20x9 +38 wheel. I am running the 245 now just to eleviate the rubbing issues, however, I think I could have went with the 255 in this brand tire without rubbing issues. My last set of tires were 255's, the brand tire had a more squared off edge that rubbed more often than I liked.
You can run either size....just figure out which tires round off a the edge more....and plan on doing slight fender mods....nothing crazy.
Old 08-25-04, 08:39 PM
DaJark
DaJark's Avatar
Default Brand
What brand would you guys recommend for most clearance? 245 35 20
Old 08-25-04, 09:58 PM
rominl
exclusive matchup
rominl's Avatar
come on, 1/2 finger front and 0 in the back, that's not slammed they aren't tucked!
rominl
exclusive matchup
rominl's Avatar
Default Re: Brand
well so3 is round, but it's loud too. dunlop sp9000 is also pretty round
nitto, perelli, yoko, they are all square
BUSTN
Wheels, Tires & Brakes Forum
12-07-04 01:23 PM
bmoon_007
GS - 1st Gen (1993-1997)
08-24-04 09:55 AM
Lettuce
02-25-04 08:41 PM
GS400_PUSHER
05-04-02 07:20 PM
enginyr
19
12-16-01 05:31 PM
Quick Reply: Tire size recommendations?
