2" Daizen drop...Rub?
Old 08-24-04 | 01:32 PM
beauphus's Avatar
beauphus
Default 2" Daizen drop...Rub?
hi all...fixin to get a set of 20's staggered for my GS...20X8.5 & 20X10...im definitely gonna drop it too...was thinking Daizen springs or Espelir springs. I know they are the most aggressive available without going coilover. will i have to worry about rubbing with a 2" drop on 20's? i was gonna run 275's on the rear. thanks all!
Old 08-24-04 | 02:14 PM
Neo's Avatar
Neo
The One
Maybe. What offsets?
Old 08-24-04 | 03:15 PM
beauphus's Avatar
beauphus
off sets will be custom to my spec...i want a nice aggressive look...
Old 08-25-04 | 02:42 AM
HKGS300's Avatar
HKGS300
If you want to play safe ... go for coilovers ...
Old 08-25-04 | 02:45 AM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
well, if it's custom, then read my guide in the wheels/tires forum on wheels fitment. it should give you a very good idea
Old 08-27-04 | 01:03 AM
Blackened's Avatar
Blackened
IMO, it won't rub since 2" drop fron the stock will still have fender clearance from the tires for 20s
However if your rims stick out because of the aggressive offset, then it might be a different stroy..
good luck!
Old 08-28-04 | 09:34 AM
corkycal's Avatar
corkycal
dont forget the type of tires that's going to be used has an effect on rubbing or not. some tires have a rounded edge and some a square edge.
Old 08-28-04 | 05:20 PM
Blackened's Avatar
Blackened
I second that
Old 09-08-04 | 08:37 PM
Dislexic's Avatar
Dislexic
Shouldn't rub unless your rims have a badly sized offset.
Old 09-19-04 | 07:14 PM
Dislexic's Avatar
Dislexic
Rubbing has everything to do with a rims offset.
jtrice
10-05-15 01:56 AM
amoney805
10-12-13 10:56 AM
trinituner
09-25-09 09:40 AM
Silver GS
Suspension and Brakes
55
08-14-08 06:03 PM
kietlander
Wheels, Tires & Brakes Forum
09-11-05 06:06 PM
