Serious Brake Help Needed
Here's the problem:
I bought my wheels used from a member here awhile back. I was TOLD they would fit a big brake setup with no problem. I am beginning to believe that's total crap.
The member swore by good fitment but didn't know the offset. The wheels were still a good deal but now that I want to invest in a BBK, I need to know what, if anything, will fit.
I was reading around and read something about 2.75 needed between the rotor and the wheel. I have included a picture of a trusty ruler and the amount of space between the rotor and the wheel at 2.1 or 2.2. I may be measuring from the wrong spot though and was looking for some clarification from anyone who knew a bit or two on the subject.
Thanks,
Anthony
Thanks,
Anthony
You can try to get some more info on the Rotora BBK.
The Rotora has one of the 'thinnest' calipers. I do not have any information about the GS kit, but I remember that i saw IS300 cars with standard 17" and 18" wheels using this kit.
The One
Hey Anthony,
If it is easy to take off your front wheel, the quickest thing to do is to try the StopTech templates:
http://www.stoptech.com/wheelfitchart/lexus.htm
Pick the kit you are considering or try them both since you already have the wheels off. Unless they changed it recently, the Rotora 4-piston template was not as accurate for me and I had to play with the pdf scaling to get it to the right size. If the StopTechs fit, then the Rotoras will fit. There is a couple of mms difference. If the StopTechs do not fit, then you'll need to play with the Rotora template. Steve has them. I'm not sure if I have mine anymore or else I'd send it to you.
If the StopTechs do fit and there seems to be a lot more space left, then you can try the templates from AP Racing and Brembo if you are considering them. The TTs will need AT LEAST the APs and Brembos. Also on the Rotoras, unless they have a new template, the prelim one for the 6-pot they sent me (which was very rough) required even more space than the APs/Brembos so they are big calipers.
Good luck. Post back or email me if you need more help.
LOL, the wheels aren't off and it isn't easy to do at the present time. I wish things were easier. lol
Thanks for all the advice anyways though. I sent Steve a PM.
Another thought I was thinking about was that my front's are 19x8 and the rears are 19x9.5. I don't think the other member would of gone with such a small figure (x8) if not for BBK clearence. Ah so confusing. (
-Anthony
-Anthony
The One
-Anthony
-Anthony
A good shot of my fingers fitting between the spoke and caliper if that means anything?
-Anthony
-Anthony
But as Neo said, the StopTech template is definitely a good thing to use. And they have two templates, one if the car isn't going to be lowered much (like L-Tuned) which would fit more rims, and one if the car is going to be able to be lowered more which needs more clearance.
Originally posted by bitkahuna
If you can only fit one finger width between your spoke the stock caliper you have no chance of fitting a big brake upgrade. With my HREs I could get almost 3 finger widths between my spokes and the stock calipers.
Ah well, all is well that ends well I guess.
I'll just use the money for Sways and Strut Bars
Thanks guys,
Anthony
-Anthony
-Anthony
This is my major problem. The original owner could provide no offset or disk information.
As for disk fitment, that's fairly easy to see. Why don't you post pictures of the front rim? Looking along the car, and show lip, spoke angles, etc. I'd say generally if the spokes don't curve out from the center a fair bit before going back into the edge of the rim, they're probably not very high clearance.
Also, do you know the brand and rim size/width (I asume you do) - if so, maybe you can find the offsets the rim was/is offered in (I'm assuming it wasn't a custom rim).
