Wheel play?
Originally posted by Bryan858
You hit it right on the nose, only free play is at 3+9 not 12+6, great way to describe by the way rather than horizontal.... I guess I'll just have to save up and replace the whole rack... I didn't hit any curbs and I only noticed it after putting my stock rims back in after lowering it, I did not have any problems after the drop and new 17" rims but I recently put my stock rims back on and then the problem started... I might open it up this weekend and try to come up with a fix other than replacing... If I do I will definetly post and let everyone know so that thoose with the same problem can save some time and money... Thanks again guys...
Kaotiq, your power steering belt might just be to tight... Its usually the cause for noise, especially if you just replaced it because it may have been over tightned when reinstalled... Hope this helps you out... Steering issues are no fun at all... Are you planning on replaceing the whole rack and pinion set? Keep me updated on what you do to fix....
MIGS
Performance & Maintenance
12
11-14-10 06:25 PM
