trd stb installation
Old 10-06-04, 10:01 AM
gs4rocks
gs4rocks's Avatar
Default trd stb installation
I have trd stb installed on my gs400, and it makes annoying vibration noise at idle because it is touching the engine cover slightly.
I had the original mounting plate removed when putting in the stb. Does anyone have the same problem?
I wonder if others either put the stb over the original plate or added spacers to raise the bar.
Old 10-06-04, 12:50 PM
rominl
exclusive matchup
rominl's Avatar
i have the original plates, and with that i have very very close fitment. i guess without it you will rub
Old 10-06-04, 02:43 PM
GS4DOUGIE
GS4DOUGIE's Avatar
That's weird Henry. When I installed both of ours I removed the spacers, then installed. I have no rubbing or noise
Did I goof?? Or should I reinstall the spacers on both??
Doug
Old 10-06-04, 03:46 PM
gs4rocks
gs4rocks's Avatar
When I first installed, the bar wasn't touching the engine cover. About a month later, I noticed they were touching. What it looks like is that the bar is actually slightly bent since the installation, the center being lowered.
It's hard to tell just by looking, but I put a 3 feet leveler against bar to see that. I don't really do much of hard cornering, I it's hard to believe that thick bar would bend easily.
Old 10-06-04, 10:28 PM
rominl
exclusive matchup
rominl's Avatar
Doug
actually i take it back. now i think about it, i have the spacers, but depends on how i fit the stb on. for me when the stb is on, i can shift it left and right a bit. if it's shifted towards the pessenger side, it will rub the engine cover (that's why i have a little mark there), but if it's shifted towards the driver side, it's cool
RI-Lex
03-31-10 02:52 PM
Lexy GS430
11-07-05 05:28 PM
tommyGS3
Suspension and Brakes
21
01-23-05 08:35 PM
RefinedGS
07-20-04 05:34 AM
enginyr
05-03-02 10:57 PM
Quick Reply: trd stb installation
