Tail Wiggle!
The rear end on my 1999 GS300 wiggles at moderate to high speeds, especially while driving round bends or a twitch of the steering wheel. More like oversteer. I have had the rear and front suspension redone with all new parts. Foxed! Any suggestions ? Thanks in advance...Dipil
first Welcome to club lex
since you now opened the door ,,, the door to bankrutpcy court so here goes to answer your question
the gs is known for its loose caboose , the fix will be getting a good set of sway bars (i pref the daizens mainly for its rear adjustment) then you need the toms 6 piece link set and then you must finish off with the toms rear lower control brace and as a option (which i reccc ) a rear upper strut tower bar to complete the box set up
to fully realize the effects a staggered setup (meaning wider rims and tires ) would also be recc
now break out the plastic , email carson toyota , hit up steve ganz and tell him big ed from florida sent you so i can get my commissions
good luck and you have been warned
Replaced all stock parts except Tires which are in good condition.Had themchecked. Dipil
The rear end (particularly on a GS300 with the 16" tall tires) wiggles because the springs are soft, the shocks have a lot of travel, the sway bar is wimpy, and there's not much bracing back there. If you replace all that your car's rear end will be tighter than Lance Armstrong's!
All the suspension mods-coilovers, sway bars, chassis braces of various types- all help in different ways and to varying degrees. If your car is totally stock, I don't know how much help just adding the Tom's RLCB (rear lower chassis brace) for example, would help solve your particular problem.
Most people start off with upgraded tires/wheels and shocks & springs or coilovers. Then continue with the other stuff to really button down the ride and tame that chassis flex (wiggle).
For my car, the most noticeable improvement for that problem was the installation of the rear lower chassis brace and the rear strut tower bar (RSTB). That really boxes in the rear end of the car and stiffens it against the cornering loads.
If you get a chance, ride in-or drive- one of the members here on CL that have done some of these mods and you will be amazed at the handling capability of the GS! For questions on specifics, do some searches and you'll find a LOT of good info.
SUPRATRD
06-24-01 06:52 PM
