gs suspensions
Re: gs suspensions
Originally posted by gs3ee
does anybody know if the springs are the same on the 300 and 430s being that everything else but the engines are identical.
The One
I am not sure about the stock springs but the L-Tuned springs are the same for both GS4s and GS3s. The weight of the engine is not that different either as the V8 has an aluminum block while the I6 is cast iron. This is partly why RMM was able to reconcile putting a GS430 engine into an IS.
Sorry I don't have part numbers and such for the OEM parts to verify for you but just wanted to give some insight.
Guest
Posts: n/a
Re: Re: gs suspensions
ANYBODY HAVE A CLUE
ANYBODY HAVE A CLUE
The stock springs are the same. The aftermarket springs are the same.
I am also going to move this to the section it should have been in.
exclusive matchup
Originally posted by Letsride
The 2 vehicles are different weights and different balance. The rates will be different......
and yes they share the same springs setup
Not too sure about the US models, but the Aristo Twin Turbo and the Aristo N/A use different shocks. Also the part no are different.
The Aristo TT shocks are stiffer than the NA.
