Need Help!! (20s rubbing)
Old 11-17-04, 10:20 PM
rominl
exclusive matchup
rominl's Avatar
Originally posted by DaveGS4
I know what is meant by this, but I've never seen pictures of where its been done.
Does anybody have some good clear pics of shaving (and the end result) they can share? (and no Henry, this doesn't mean you with the Gillette in the AM )
hahah dave, i am laughing so hard on this one man
Old 11-17-04, 10:22 PM
rominl
exclusive matchup
rominl's Avatar
Originally posted by ILOVEGIRLS
im not so sure "cutting" would be a gret idea. i did this before and maybe too much was cut off but it caused a seperation between the fender well and the actual body panel. it seperated because the trim was the 2 panels pressed together. the shop only cut off 1/2 of the trim and caused this to happen.
actually, i don't think it's going to affect anything at all. i ahve seen couple of GS with the whole rear fender tab cut out, it's all fine. the 4 screws in the rear fender tab, it's just to hold tha tblack plastic strip to the tab, nothing more. and the fender together with the fender well, it's put together very well. the car that i saw it cut all the way, they are still fully attached with each other
on the other hand, rolling is a pretty bad idea on the gs compared to shaving. coz' of the design, when you roll it, you can very easily chip the paint on the fender. now you ar talking about pretty expensive repaint job
Old 11-17-04, 10:23 PM
rominl
exclusive matchup
rominl's Avatar
and thanks to rmmgs4 again for all the pics. i can tell at least 4 norcal guys doing this on our cars before already. in fact i did mine right at rmmgs4's grage. with the right tool (read, grid 60 sand paper!!!!!!!!!), it's nothing more than a 30 mins job. very safe, very easy. just make sure you mask out the fender surface to be safe
Old 11-17-04, 10:51 PM
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
When I had my rear fenders pulled/rolled, the professional hammered the inside trim so it got really close to the fender.
He didn't want to shave it because it would weaken the fender wall. I am happy because it looks like I have a lil fender flare action. hehe Here's the end result, as I really wanted this very aggressive setup taken at a friends house.
It looks like it rubs, but it does not as the sidewall on my tires angle inward.
Old 11-18-04, 02:39 PM
HKS_GS430
HKS_GS430's Avatar
after u cut it off make sure u touch it up with primer and paint,,u can get an xtra 1/2 inch of clearance by cutting the lip off,
Old 02-12-05, 02:12 AM
newyorksc
newyorksc's Avatar
sorry for bringing this thread back up.. but i am almost positive that i will be rubbing on my wheels tomorrow (when i install new wheels), so i will be posting pics throughout the day of my progress etc.. and maybe i can get some guide in terms of how much rolling and/or pulling needs to be done.
lex aristo, that has to be one of the nicest, cleanest, fender mods done. i hope mine will come out like that.. what size rim and tire are you running?
im going to bolt on my new wheels tomorrow.. just to see how much i need to pull, roll, etc.
i will post pics for you guys.. and maybe i can get some opinions.. i won't have to roll too much because the offsets are made for the car, but i just need to a little because i'm going to slam my coilovers.
Old 02-12-05, 11:56 AM
TOMLEXUS
TOMLEXUS's Avatar
RICHYRICH, what are the size of your wheels / tires? offset of your wheels? I like to get some 20'' for my GS4, worry about the rubbing, thanks.
Old 02-12-05, 09:42 PM
newyorksc
newyorksc's Avatar
what do you guys think? i don't even really need to pull my fenders, just roll.. right?
rolling is a DIY, pulling i should have a shop do, right? I couldn't find RMMGS4's write up on how to roll fenders.. how do you roll fenders?
Old 02-12-05, 09:45 PM
AutoCoutureSC
AutoCoutureSC's Avatar
how sad ... you don't trust the SC guys advice?
newyorksc
newyorksc's Avatar
Lol autocouturesc.. i trust SC guys advice,.. always good to get as many opinions as possible. and this is a general topic for all car owners who are trying to fit bigger wheels (-) the rubbing.
for more pics check out this thread
https://www.clublexus.com/forums/sho...5&page=1&pp=15
one way i saw was by using a belt sander.. it was hard to see in the pic what exactly he was sanding down.
Old 02-14-05, 10:32 PM
rominl
exclusive matchup
rominl's Avatar
instead of rolling i think you should shave the fender with belt sander, that's probably safer
Dream005
23
08-30-12 06:57 AM
iridebmx
SC- 1st Gen (1992-2000)
03-30-11 08:52 PM
HEY430
Wheels, Tires & Brakes Forum
05-15-10 05:17 PM
574-SC300
Chicago Lexus Club
01-11-07 05:49 PM
XenonES3
03-11-03 03:08 PM
Quick Reply: Need Help!! (20s rubbing)
