Need Help!! (20s rubbing)
Old 11-15-04, 11:05 AM
RICHYRICH
RICHYRICH's Avatar
Default Need Help!!
Just put 20's on my 00 GS4, and there is rubbing at high speeds when going over bumps, So i then rolled the fenders and there is slight rubbing only on one side I need a fix. Do I tell the car shop to cut the well when I put the HA's on or what ?
Old 11-15-04, 01:11 PM
400DGRZ
400DGRZ's Avatar
What setup are you running?
Old 11-15-04, 09:55 PM
rominl
exclusive matchup
rominl's Avatar
yeah, you can just ask them to shave the fender (i suppose it's the rears?). i think you have too high of an offset. just shave it and you should be fine
Old 11-16-04, 08:32 AM
RICHYRICH
RICHYRICH's Avatar
What do mean by shave it ?
Old 11-16-04, 10:02 AM
Neo
The One
Neo's Avatar
Cut off some of the fender tab/lip. If you look at the fender wheel well, there is a little lip that is covered by a black trim. Cut some of it off to give you more room.
Old 11-16-04, 10:20 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,260 Likes on 1,373 Posts
I know what is meant by this, but I've never seen pictures of where its been done.
Does anybody have some good clear pics of shaving (and the end result) they can share? (and no Henry, this doesn't mean you with the Gillette in the AM )
Old 11-16-04, 10:37 AM
Neo
The One
Neo's Avatar
I'll try and take some pics later if noone has posted any.
Old 11-16-04, 12:59 PM
ILOVEGIRLS
ILOVEGIRLS's Avatar
im not so sure "cutting" would be a gret idea. i did this before and maybe too much was cut off but it caused a seperation between the fender well and the actual body panel. it seperated because the trim was the 2 panels pressed together. the shop only cut off 1/2 of the trim and caused this to happen.
Old 11-16-04, 01:13 PM
Neo
The One
Neo's Avatar
Which trim and 2 panels are you talking about?
Old 11-17-04, 01:23 AM
RMMGS4
Northern California Regional Officer
RMMGS4's Avatar
There's no problem with the body panel separating from the fender since we typically only need to take off half of the lip.
Rolling the GS fender is not as good a method since the black trim would need to be removed, plus there is always a chance of paint cracking at the rolled edge.
I've done shaving on a bunch of NorCal cars over the past 3 years and we have not seen any problems from shaving the lip.
We usually need to grind off the lip up to the screw heads that are holding the black trim.
In extreme clearance cases we have gone a lot further and actually removed the trim and the screws all-together, without any problem.
Here's the stock lip.
Old 11-17-04, 01:25 AM
RMMGS4
RMMGS4's Avatar
The shaving is done using a belt sander and 50 or 80 grit sandpaper.
Old 11-17-04, 01:32 AM
RMMGS4
RMMGS4's Avatar
Here's the finished lip with about 1/4 inch of the material removed. You can see that we shaved away all the material up to where the screw heads are.
Attached Thumbnails Need Help!! (20s rubbing)-rear-shaved-quarter-inch-1.jpg
Old 11-17-04, 01:44 AM
RMMGS4
RMMGS4's Avatar
There are some cautions that need to be taken when using a belt sander. I better do a full DIY write up in the near future. I promise.
Now for the front fender there is some slight rolling that can be done without much risk of cracking paint, plus some plastic forming of the inner liner with a heat gun.
I shaved the rear lip and rolled the front lip on the wifeys IS.
Check out that article here:
INDGOGRL : "My IS Story: Day 1"
https://www.clublexus.com/forums/sho...&pagenumber=10
Also a follow up article on my on car : "285/30-19 maxed out to the lip, NO Rubbing." :
https://www.clublexus.com/forums/sho...ght=no+rubbing
Old 11-17-04, 02:01 AM
Neo
The One
Neo's Avatar
Thanks for the pics RMMGS4. Saves me from having to take off the wheel to get the camera in there.
Old 11-17-04, 08:55 AM
RICHYRICH
RICHYRICH's Avatar
THANKS for the info and pics !!
Quick Reply: Need Help!! (20s rubbing)
