Spring rates?
Spring rates?
Anyone know the stock SC300 spring rates?
I've got Eibachs but I want to go a little stiffer but not too stiff. The following information is relates to the supra from MKIV.com. I'm not sure if the NA and TT supras are the same or different. There are different P/N's for Eibach NA and TT springs.
Spring Type Front lbf/in Rear lbf/in Drop Front Drop Rear
Stock linear 430 219
Eibach proggressive 370->510 180->263 1.2 1
H&R progressive / linear 470->495 250 1.1 1
Any idea where the stock springs and Eibach's for the SC300 fit in?
Sorry about the formating
This is a very bad method on my part but I jus installed my Pro Kit and it feel much stiffer than stock, it's not to the point of being bad. So I'm sure they are under or close to the light end of the Pro Kits range.
Like I said, a very bad answer, but it's something to go off of.
