struts and mounts question
I recently bought a used (2001) gs430 and took it to the Lexus dealership for an inspection. One of the things they recommended doing was something to do with the struts and mounts and stab. bar bushings for $425. They said that it was some recommended fix having to do with "metal on metal" and that it would have been covered when the car was under warranty. I didn't really understand what the guy was saying but these are the same guys that said I needed a new $1100 windshield to fix a wind noise problem that was fixed for $30 by a local glass guy
Anyway, is anyone familiar with a strut/mount/bushing problem with 2001 gs430's and know what they were talking about? What I'm really wondering is - I'm planning to get some lowering (perhaps l=tuned) springs and shocks. When I get these, will it take care of the problem the lexus dealearship is referring to anyway, or do I need to get that work done as well?
Thanks for any advice.
Re: struts and mounts question
Spend the $425 on a nice set of sway bars with bushings. I have seen some cases where the bolts on the sway bars would come loose and cause a rattle. But I don't think this applies to you. Don't fix it if its not broken. You'll be a lot happier after you've gotten your springs, struts and sway bars. Take pics after you've had that done. Good luck.
Will
OK - how do these two items look - l-tuned shocks and l-tuned springs? I like the idea of a mild drop and mild handling improvement - don't want anything too extreme.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Is this enough for lowering and flatter cornering or should I get anything else as well (hope to keep the total cost of suspension mods under $1000) . Should I get sway bars as well (l-tuned)? what would they add that the shocks/springs wouldn't? Also where do I get new shock mounts and how much are they? OH - what's the difference between shocks and struts and do I need new struts as well as shocks?
Thanks again for all the help guys.
Thankyou DetMich1 for the clarification - where did you get your l-tuned shocks/springs installed?
So adding sway bars to the gs430 will increase the car weight since you're adding something new rather than replacing something - is that correct?, or do the cars come with sway bars from the factory?
One other question: the dealership listed that I need new stabalizer bar bushings. Are those another item that I can upgrade for better handling - I've no idea what those are.
Guess I'll be learning a lot about cars with my new gs I've had plenty of cars before, but I've never been excited enough before to consider moding or do anything other than just get in the car and drive it.
*******I got my shocks and springs installed by a local mechanic who has a small shop specializing in Lexus service.
*******The car does come with sway bars from the factory. You can see a picture of the aftermarket swaybars by looking on line at a number of sites including Carson Toyota's L-tunedparts.com There would be some increase in weight but I doubt it would be more than 20-30lbs extra depending on how much heavier the new ones were vs the original.
********Daizen, who also makes a well regarded set of sway bars, markets an aftermarket stabilizer (read:sway) bar bushing. It is made of hard Polyurethane (nylon) and replaces the stock rubber bushings from the factory. This results in less flexibilty than the stock rubber bushings and gives the feeling of a slightly stiffer sway bar without actually changing the stock sways. cost is about $30 and installation is fairly simple especially if the car is on a hoist. Any competant mechanic should be able to replace all 4 (2 front and 2 rear) bushings in about an hour or less. If you do it while the car is getting an oil change or new brake pads it will already be up in the air and could be done for minimal extra charge. I put them on my older SC400 with a noticible improvement in cornering.
Originally Posted by HKS_GS430
so the ebay listing is legit? brand new or slighty damaged boxed good? was it delivered in a timely manner
OK -here's what I"m planning to get:
1. l-tuned shocks
2. megan racing springs
3. daizen sway bar bushings
4. new shock mounts
Hopefully this will take care of the problems the dealership was referring to as well as improve the handling and reducing the wheel-well gap.
I've got one question on each of the above:
1. Will l-tuned shocks stand up to the eibach or megan springs? I saw romini say in another thread that the stock shocks would "blow fast" with lowering springs. Would the l-tuned shocks fare any better?
2. I was thinking about l-tuned springs becuase I don't want too harsh of a ride, but after looking at the gap between my tires and fender - I don't think a 1" drop will be enough to look good (I've got 245x40x18 all around which are the same diameter as stock 16s"). Anyway, now I'm considering megan springs because they're very cheap and drop the car about 1.9". I'm just wondering if I can still expect the car to ride reasonably comfortably with these springs.
3. The dealership said I need new stabilizer bushings. Are these the same as sway bar bushings?
4. I checked the tire-rack and they don't carry shock mounts for the gs430. Any other ideas on where I could find some of these?
Thanks
1. l-tuned shocks
4. new shock mounts
Thanks
1. l-tuned shocks
4. new shock mounts
Thanks
1. l-tuned shocks
4. new shock mounts
Thanks
3. yes, sway bar or stabilizer bar also sometimes called ANTI-sway bar all the same thing. I think I will also add the Daizen bushings to my GS very small price for an increase in cornering performance. Obviously not as dramatic as changing the sway bars themselves but the cost is about 1/10 of buy new sway bars. I already added them to my SC with very nice improvement in reducing body roll in hard cornering.
4. Did you check with Brandon or one of the sales reps at TireRack? Many of the components on the 400 and 430 are the same. Obviously, this would be a cost effective time to change the shock mounts when the shocks/springs are out of the car, but if your GS is relativley low mileage their replacement may not be requuired, depends on wear.
What style of rims have you got? My next mod will probably be a set of 18 X 8.5 rims and 245/40-18 tires. Right now I am leaning very strongly toward the SSR GT3. Did your car come with these aftermarket rims or have you had the opportunity to compare the ride and handling with the stock setup?
Detmich1 - thanks for all you help - I appreciate it.
I have 18" chrome adr sterlings. I've read that the adr's aren't the highest quality rims in the world, but they look awesome on my black gs. I just put the new tires/wheels on last week and I think it rides better and quieter now (from the stock 16s that were on it until last week). With the lower profile tires I was expecting a noisier/harsher ride, but I think the new tires I got (pirelli pzero nero m&s) made up the difference. I'm very happy with my wheels/tires - now I just need to do the suspension. By the way, I got the chrome adr sterlings on ebay for like $540 + $125 shipping - so $665 for 4 chrome wheels - pretty good!
