View Poll Results: Favorite suspension setup?
HKS Hipermax II
![](https://www.clublexus.com/forums/images/polls/bar2-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar2.gif)
![](https://www.clublexus.com/forums/images/polls/bar2-r.gif)
![](https://www.clublexus.com/forums/clear.gif)
37
17.96%
Tein CS
![](https://www.clublexus.com/forums/images/polls/bar3-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar3.gif)
![](https://www.clublexus.com/forums/images/polls/bar3-r.gif)
77
37.38%
Tein FLEX
![](https://www.clublexus.com/forums/images/polls/bar4-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar4.gif)
![](https://www.clublexus.com/forums/images/polls/bar4-r.gif)
53
25.73%
JIC FLTA2
![](https://www.clublexus.com/forums/images/polls/bar5-l.gif)
![](https://www.clublexus.com/forums/images/polls/bar5.gif)
![](https://www.clublexus.com/forums/images/polls/bar5-r.gif)
39
18.93%
Voters: 206. You may not vote on this poll
which suspension set up?
#31
The issue of pillow mounts with adjustable camber only applies to cars with a MacPherson strut suspension. Our cars use upper and lower A-arms, so adjusting the angle of the shock via the pillow mount would have no effect on camber.
#32
Was not part of the poll, but how about the OEM MKIV Supra TT Springs, Shocks and Sway Bar combination? It is a considerable handling upgrade from stock SC300, lowers the car and settles down the handling. You can get the parts for under $200, though you will absolutely have to purchase TT sub-frame mounts for the rear sway bars for another $65 each.
#33
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#34
I found mine from some guy on Supraforums who thought his car would be cooler with some Eibach springs
, they cost me $150 shipped, and the entire rear bar setup was $60 at a local wrecking yard.
Best mod per dollar yet IMO.
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
#35
Originally Posted by jgscott
Where can you find Supra TT springs, Shocks, and sway bar for under $ 200 ? ![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
I dont know about you but i would rather spend 100 more and know the seller is ok,than get ripped off.
Plus Supra owners are WAAAAY harder on their rides in general.
#37
will I need to upgrade to performance shocks if I am lowering my car? because I heard that the stock shocks will have more weight to support and that they will blow out let me know guys
#38
i actually get my zeals hopefully this week, i'll try to take pictures of the install!
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
#42
JIC IS THE BEST I agree with AZlex...i've had the flex and the hipermaxx (on supra) The JIC has a harder spring rate but strangley enough gives the best ride.....also, check most of the formula D drivers.....many have converted to JIC!!!
#45
They're the TR-1 dampers, actually for the Supra.
http://www.blitz-performance.com/Blitz_Susp_TR1.htm
