supra tt sway bar conversion (parts needed?)
Originally Posted by PERRYinLA
Those are good thoughts but I hope you don't really think all American roads are like those in Florida.
Florida is I believe the flattest state in the union. If you'd like to see some nice curves, come to <insert your state here>. (But I will grant that Florida has the smoothest roads in the world- stiffen up your suspension there, and you'd think the ride is not affected at all, until you ventured out of state!.)
Yes, ride quality versus handling. It is hard compromise.
I do not know if I made myself clear enough in my previous post. I`m not advocating stiffening suspension behind Supra TT setup and low profile tire setup. I do belive it is sporty enough for street use regardless of state and factory engineered to work together.
I suppose it depends on your spring rates, but the TRD rear bar is pretty firm, sounds like the oem TT bar is enough, even on the track.
That's what I found from some Supra owners awhile back anyways.
I wouldn't mind trying a firmer front bar though, just to see what the trade-off would be.
I'm not sure the question of end links ever got resolved. Some people have said they needed them for the TT bars, I have a '96 and the TT bars bolted up to my stock end links (front and rear). I suspect it may be an issue with the model year. It would be useful to hear from the folks who have done this mod as to what year/which end links are needed.
Originally Posted by MikeFD3S
I will be be putting the Tanabe front and rear swaybars on my 92 sc300. Will post pics. The Tanabe swaybars are chromemoly=lightweight and super strong
![Arrow](https://www.clublexus.com/forums/images/icons/icon2.gif)
i hate beating a dead horse but...
lots of contradiction with the supra tt rear sway bar install throughout this forum. Some had no problem, others needed endlinks, subframe mounts and subframe cushions off the TT as well as had to weld some aluminum plates, etc. I'm GUESSING difference may be in the year and model of the SC300/400. I've got a 95 sc300 and just got the rear sway from the TT which looks to be shorter in width than stock, so i'm ordering all the extras and hopefully get it in. I think the 96+ fit differently?
meanwhile.... any one have pics of their installed Supra TT (or Supra tt spec aftermarket) rear sway bar? Please state year and model and let's put this puppy to rest!
Thanks!
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Thanks!
On the Supras, the two, rear-most subframe mounts have saddles built in to them to hold the swaybar. The subframe mounts are swappable between the Supra and SC.
The endlinks I used on my '92 SC4, with the Supra rear bar, are the ones that were on the car originally.
Sorry no pictures, and the rear mufflers did need to be removed for access.
So from you guys who have installed sways, supra/trd/daizen or otherwise, how is you ride quality now? Is it louder, are bumps more noticible? I know high speed turning is improved but does it feel any different in low speed turns and everyday driving?
Originally Posted by newyorksc
i thought daizen sways handle better than trd sways
i think daizens were 150% stiffer than oem and trd sways were 132%
The Daizen are more stiff
I like em '
Hands up if you have driven a Supra TT, Do you want your Luxo Lexus to ride like that?
If you want to IMPROVE the handling, replace the soft, saggy, worn bushes in the suspension arms and do the swaybar bushes at the same time, you dont have to go for fancy after-market kit, just use the Vlamos rubber bushes and std Lexus parts.
The car will be totally transformed, smoother, quieter and it will handle better, trust me, everyone who has driven Yakuza since the suspension overhaul has been stunned at the improvement.
And I had previously considered fitting the TRD or TT rear swaybar to combat the wobbly back end but now it just aint called for.
Originally Posted by rscott
endlinks are fine. its the subframe mounts you need from the supra.
Also, when I read this link, there is directly conflicting info. You need the end links, no, you need the subframe mounts. Well, I tried to mount my TT rear sway bar without Supra Sub Frame mounts. Not going to happen.
Finally, let's be clear on the front TT sway bars, anything needed to put them in (like Toyota TT end-links or sub-frame mounts) or do they just hook up??
Help please, only from those who went under the car and did it...
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
