supra tt sway bar conversion (parts needed?)
Old 12-20-04, 09:12 PM
newyorksc
newyorksc's Avatar
Default supra tt sway bar conversion (parts needed?)
i know this topic has been brought up many times before.
i searched the forums and found several people who have swapped their oem sway bars with supra tt sway bars or TRD supra sway bars.
anyway, I purchased a set of TRD supra sway bars and I am just awaiting shipment.
The package came with front & rear sway bars, bushing and bushing brackets with grease fittings mounted on them. I bought them preowned from supraforums.
What my question is.. what exactly do I need (if anything) to make these fit on my SC.
Do I need Supra end links? I heard people who take supra tt sway bars and put them on their SC need supra end links because the ones from the tt and sc are completely different. But then again, I was reading a post where the guy took TRD sway bars from the Supra and fitted them on the SC with stock end links. So i'm not sure.
Either way, is there anything else I need besides endlinks -if so?
All help is appreciated.. thanks in advance for all responses.
Old 12-20-04, 09:24 PM
Koma
Koma's Avatar
Yep the Supra end links. That's all you need. Everything should bolt on perfect with the Supra end links. You can try using the stock end links but I'm almost definite they're much different.
Old 12-20-04, 09:26 PM
One HoT
One HoT's Avatar
Many info laying around if you search throughly.
https://www.clublexus.com/forums/sho...upra+sway+bars
Old 12-20-04, 09:33 PM
Koma
Koma's Avatar
Oh I see... trying to show me up huh?
Heh... taking one step further, CL is definetely a family. A car crazy family.
....Except those who got banned.
Old 12-20-04, 10:13 PM
newyorksc
newyorksc's Avatar
thanks for the responses.
so from reading what you guys have told me.. i will need
subframe mounts, subframe bushings, end links?
we should just create a list of what exactly one needs, and sticky it, as it seems to be a very common upgrade.
Old 12-20-04, 10:55 PM
Koma
Koma's Avatar
I think most people go for the aftermarket Supra suspension. Because it's meant for throwing your car into turns really fast. Supra swaps are still better than SC stock because our cars were meant for luxury and sporting around a crazy fast engine that they decided "HEY! I got a crazy idea, let's slap in a fast engine into a luxury car.. and then tune it for luxury! So our customers will complain for more speed from the engine." ...Oh the potential.
Personally I would look into what the aftermarket has to offer for the Supra.
Old 12-21-04, 02:30 AM
rscott
rscott's Avatar
endlinks are fine. its the subframe mounts you need from the supra.
Old 12-21-04, 12:10 PM
FortuneLS
FortuneLS's Avatar
has anyone tried the do-luck front and rear sways?
anyone know the price? i am thinking of going this route any info on these sways would be helpful.
Old 12-21-04, 01:10 PM
verylost
verylost's Avatar
Why not get the Daizen sways? They were designed for our cars and they aren't dangerously close to the oil filter like the TT sways.
Old 12-21-04, 05:52 PM
SCV8
SCV8's Avatar
You need the two, rear most sub-frame mounts; they double as the swaybar mounts.
Old 12-24-04, 07:09 AM
mteele
mteele's Avatar
Thats what I'm thinking. And its easier to do since you dont have to hunt down those subframe mounts on SF.
Old 12-24-04, 01:15 PM
newyorksc
newyorksc's Avatar
don't daizen sways cost around $500?
i bought my TRD sways for $215 so i thought it would just be cheaper to get the TRD ones and subframe mounts elsewhere
Old 12-24-04, 01:31 PM
rscott
rscott's Avatar
$215 is an insane price. I got mine brand new for $320.
If anyone is interested, i have a set of TRD bars with subframe mounts up for sale in the for sale forum. Its pretty close to the top. PM me or email me if insterested. rscott76@ucla.edu
Old 12-25-04, 06:39 AM
EUROJulian
EUROJulian's Avatar
There are some common missconceptions floating alround this forum on the sway bar issiue.
First is handling: It is true that stiffer "racing" sway bars better control body roll in turns. BUT there is a price to pay. Rear end of the car became more "busy", It is much easier to loose control of car in the corner and crash it. Understand that. If you are average driver w/o track expirience think twice.
Secondly if you do not use car for racing like autocross or something why would you need beefy swaybars for? American roads like ones we have in Florida have no curves at all, exept for 90 degree 4-way Stop intersections.
Next, cost effectivness. Recycled TT parts are dirt cheap and more then adequate for street appications . Then can be paint red if need to.
Wheel and tire set up, wide, low profile tires like 245/40 series combine with stock TT Supra suspension setup take care for most of the "handling" issiues SC400 may have.
Lastly, suspension setup that is a science. All you can do if you just replace various componenets w/o proper tunning is deengineering your suspension. Make car unsafe or have other issiues so often found on this forum like tire wear or such. Have that in mind.
Old 12-25-04, 10:54 AM
PERRYinLA
PERRYinLA's Avatar
Default Slightly Off-Topic......
Those are good thoughts but I hope you don't really think all American roads are like those in Florida.
Florida is I believe the flattest state in the union. If you'd like to see some nice curves, come to <insert your state here>. (But I will grant that Florida has the smoothest roads in the world- stiffen up your suspension there, and you'd think the ride is not affected at all, until you ventured out of state!.)
Quick Reply: supra tt sway bar conversion (parts needed?)
