View Poll Results: Would you be interested in having LS400 brakes on your 2nd Gen GS?
Yes, because it would be cheaper!!
55.56%
Yes, because I like the way LS400 brakes look.
22.22%
No, I still like Supra TT brakes better.
22.22%
Voters: 9. You may not vote on this poll
LS400 brakes do fit 2nd Gen GS!!
Old 04-28-08, 02:27 PM
  #151
pingu
pingu's Avatar
Henry, are you using RCA's?
Old 06-08-08, 07:58 PM
  #152
TherealFIG
TherealFIG's Avatar
For those still interested, I should have the RCA's ready soon...ones that do not affect the ride height. These will be similar to the version on the ISF. This will keep the ball joint in-line with the suspension arm and only push the steering link down...the way it should be. I will have my very own VMC to make these in the next few weeks so prodcution will not be a problem. I tired teh first one and was not happy with the geometry offset, espcially on a double wishbone suspension.
Fig
Old 06-09-08, 03:03 PM
  #153
nncastillo
nncastillo's Avatar
I would be interested once production is up and running. Thanks.
Old 06-09-08, 03:13 PM
  #154
kit cat
kit cat's Avatar
Fig
sorry to be technologically slow but why would you want to keep the ball joint in line with teh suspension arms and push the steering link down? wouldnt you want everything effected by lowering a car to be pushed back up to place to fix the suspension geometry???
Old 06-09-08, 03:25 PM
  #155
GSteg
GSteg's Avatar
^^True. That is the purpose of RCAs in the first place.
What I'm trying to figure out is how will these not affect ride height. Anytime you have spacers in between the balljoint and the knuckle, you're raising the hub and that means lower ride height. You can use RCA and still get the same ride height, providing you have longer shock/springs, hence why only those with coilovers are able to obtain the same height with RCAs.
Old 06-09-08, 06:11 PM
  #156
nncastillo
nncastillo's Avatar
Does anybody know if a 1993 or older LS calipers fit 2gs?
Old 06-09-08, 09:34 PM
  #157
GSteg
GSteg's Avatar
95-00 LS400 calipers fit. I dont know if the 90-94 will.
Old 06-11-08, 11:33 AM
  #158
pingu
pingu's Avatar
You would not want to use the 90-94 caliper anyways. Those are 2 piston.
Old 06-22-08, 06:04 PM
  #159
skperformance
skperformance's Avatar
Here is a question for all of you who have swapped brakes over to 95-2000 LS400 calipers and rotors.
What do you use for brake lines?
DO the stock 2nd gen rubber or stainless steel lines bolt right on ?
thanks
Old 06-22-08, 06:48 PM
  #160
aliga
Former Sponsor
aliga's Avatar
thanks
correct, all bolt on
Old 06-22-08, 07:30 PM
  #161
FinLIFE
FinLIFE's Avatar
just got mine bolted up. Ill post pics when I take some.
Old 06-22-08, 08:10 PM
  #162
skperformance
Would anyone be kind enough to measure the stock rubber lines for length ?
I am looking for the
1. length end to end total
2. metal fitting lengths both ends
3. rubber hose length.
I really appreciate it , thanks
Old 06-23-08, 05:32 PM
  #163
GSteg
GSteg's Avatar
If you're going with OEM rubber lines, then they'll bolt up to the LS fine. Even if you get aftermarket stainless steel, the ones for the GS will fit. It's as plug and play as it gets minus the RCA spacers.
Old 06-28-08, 07:00 PM
  #164
nncastillo
nncastillo's Avatar
I just installed mine and I chose to go with the shaving of caliper route. Be very careful when grinding off some metal. I actually shaved too much and put a hole in the caliper. It was all good, though. It only cost me $20 dollars to get the hole tig welded shut.
Old 07-19-08, 01:30 PM
  #165
kit cat
kit cat's Avatar
does anyone have a pic of the inside of an installed LS caliper? Preferably the passenger side where the sensor is.
Quick Reply: LS400 brakes do fit 2nd Gen GS!!
