View Poll Results: Would you be interested in having LS400 brakes on your 2nd Gen GS?
Yes, because it would be cheaper!!
55.56%
Yes, because I like the way LS400 brakes look.
22.22%
No, I still like Supra TT brakes better.
22.22%
Voters: 9. You may not vote on this poll
LS400 brakes do fit 2nd Gen GS!!
#166
#167
This is not your tricycle your talking about here guys. I would not put that on my sons toy, much less my car. Things used with braking systems need to be built with a huge safety factor engineered into the parts.
I will pass....
BP
I will pass....
BP
#169
The bracket is pleanty beefy for even a heavy duty brake setup. The shear on the studs is what you have to be worried about on a radial mounted caliper. I would use ARP 4340 or L19 studs in lieu of bolts.
#170
I'm trying to picture how that bracket would work...does it offset the placement of the caliper to a higher location to clear the bolt? But then again, if it's a L shaped bracket...is that for a GS application???
#171
This link may or may not help you
http://trdparts.jp/english/parts_monoblock.html
I did the F-sport brakes on a friends IS350. They are from stoptech and are radial mounted as well. The brackets look identical. EDIT: Oh and they use studs FWIW
#172
That bracket is for a GS or Supra.
these are the teaser pics we get? where are the goods?
#174
#176
http://night-pager.com/English/English01.html
By the looks of that it'll atleast cost 3 bills
You can buy F-sport brakes at the stealership but they are only for the IS series right now.
#177
LS/JZA80 calipers do not have the bolts go through the calipers like the F-Sport one you posted. It goes behind the caliper and onto the knuckle. In an application like the TRD and F-Sport, I see the use for the L shaped bracket. BUT for the JZA80/UCF21, I don't see how it'll work. You'll either have to offset the LS caliper higher or have RCA brackets.
#178
I guess im confused by your question confusion
The premise of that bracket posted earlier is to use a LS430 caliper on a GS.
This thread was created for the LS400 caliper as it is a regular mount and does bolt right up to the GS knuckle if you use spacers or an RCA.
#180
