View Poll Results: Would you be interested in having LS400 brakes on your 2nd Gen GS?
Yes, because it would be cheaper!!
55.56%
Yes, because I like the way LS400 brakes look.
22.22%
No, I still like Supra TT brakes better.
22.22%
Voters: 9. You may not vote on this poll
LS400 brakes do fit 2nd Gen GS!!
Old 12-03-08, 03:26 PM
  #181
sam430
sam430's Avatar
Did you do the front and rear? Is the rear caliper lighter too(probably not worth doing)?
Old 12-03-08, 03:55 PM
  #182
twojayzee
twojayzee's Avatar
The larger pad surface area is what helps. People will argue that its not worth the larger rotating mass. They might be right if your trying to knock four hundreths off your ET, but IMO they are worth it for the street.
Old 12-03-08, 09:04 PM
  #183
sam430
sam430's Avatar
Well, I think it's worth it because it's lighter than the Supra TTs and give about the same performance...but I was talking about the rear caliper of the LS430... I was wondering if it's much lighter than the gs430s.
Being the front caliper is about 5 pounds lighter than the Supra TT is worth tinkering and making it fit. ...then again, stock setup already works well.
***edited my bad...you were talking about something else. But I'm gonna leave it up because...I think this mod is worth it to tinker around with.
Old 12-04-08, 08:10 AM
  #184
sakataj
sakataj's Avatar
maybe im confused, but i think its u sam. he's not putting those f-sports on a gs series AT ALL. they going on a friends IS350. doubt seriously even if u tinkered they would fit on a gs series, would be the sickness though, that baby blue color on a black or a white gs!
Old 12-04-08, 08:11 AM
  #185
sakataj
sakataj's Avatar
n maybe im just a tard cause i just saw how u said nm, that u realized he was talking bout something else.....oh well
Old 12-05-08, 01:00 PM
  #186
sam430
sam430's Avatar
blue and silver is a perfect match...I was talking about the LS430 caliper. Hope someone does a DIY on this (without the RCA).
Old 12-06-08, 05:01 PM
  #187
sam430
sam430's Avatar
Originally Posted by aliga
you dont really need an rca for the second gen gs, all you need to do is cut off a few unused threads on stud that the caliper touches.
Has anyone gone this route? Please, please, please show pic... TIA
Old 12-12-08, 08:38 PM
  #188
GS FONZy
GS FONZy's Avatar
Front Calipers
LS400 95+ = RCAs or grinding required to fit the GS
LS430 = Brakets required to fit the GS
Rear Calipers
LS400 95+ = I would not use them since they are a 1 piston caliper
LS430 = Brakets required to fit the GS. However; there would not be much of a gain in brake performance since GS's rear calipers are already a 2 piston caliper like the Supra TT and LS430, I also doubt there is much of a weight difference. The money you would spend on brakets could be used for something more functional.
Old 12-13-08, 08:33 AM
  #189
pwesseler
pwesseler's Avatar
Did TheRealFIG ever finish those RCA's?
Did anyone ever go with the combo of a smaller RCA and shaving the top threads off the tie rod? That would seem to be the safer bet.
Old 12-13-08, 12:21 PM
  #190
sam430
sam430's Avatar
Originally Posted by GS FONZy
Front Calipers
Thanks! I wanted to go the route of grinding the thread but I read somewhere that there exist an 1/4" or 1/2" rca that'll clear the tie rod.
Old 12-13-08, 01:19 PM
  #191
GS FONZy
GS FONZy's Avatar
There are only a limited amount of members that have 1/2" RCA's
I have not heard any performance parts places to carry RCAs any smaller than 1"
Old 12-14-08, 01:33 PM
  #192
kit cat
kit cat's Avatar
I highly recommend AGAINST the grinding to install LS400 calipers.
I've heard it is do-able but when i tried it myself, it was impossible.
^LS400 caliper on 2GS.
Old 01-04-09, 12:27 PM
  #193
sam430
sam430's Avatar
Yeah, whatever happened to TheRealFig?
Old 01-04-09, 02:59 PM
  #194
Bliggity
Bliggity's Avatar
Do the LS calipers stick out as far as Supra calipers? I cannot run Supra's on my 19" MMR HR2's.
Old 01-04-09, 03:15 PM
  #195
TherealFIG
TherealFIG's Avatar
I have yet to get to them. I was hoping to turn them out on my mill as the first project, but alas, the blue giant lies still in my garage...still have not hooked up power on account of the kitchen I am supposed to finish first (wife's rules). So alas, no parts yet and I do not want to pull teh triger without protos. So hopfully I get my kitchen done...then this...then...so many other things.
Fig
Quick Reply: LS400 brakes do fit 2nd Gen GS!!
