View Poll Results: Would you be interested in having LS400 brakes on your 2nd Gen GS?
Yes, because it would be cheaper!!
55.56%
Yes, because I like the way LS400 brakes look.
22.22%
No, I still like Supra TT brakes better.
22.22%
Voters: 9. You may not vote on this poll
LS400 brakes do fit 2nd Gen GS!!
Old 09-22-10, 10:48 AM
  #226
sakataj
sakataj's Avatar
Originally Posted by Infamous 1
PHML was able to do it with his 16" oem wheels with the SAGE RCA.
and a 15mm spacer
Old 09-22-10, 02:41 PM
  #227
PHML
Master Thread Closer!!
PHML's Avatar
Originally Posted by GS FONZy
There are only a limited amount of members that have 1/2" RCA's
I have not heard any performance parts places to carry RCAs any smaller than 1"
gotta custom make them. I have 18mm RCAs sitting in the garage...but the problem is finding the high grade bolts to match this thickness.
Old 09-25-10, 09:10 PM
  #228
tom steele
tom steele's Avatar
just get a rca to lift about 3/4 of inch not hard at all i would not shave down the caliper itself. and for 400 bucks this was the best mod i have done for that cheap. hers a pic of the one i made with some 1/4 plate and washers.
Old 09-25-10, 09:12 PM
  #229
tom steele
tom steele's Avatar
and yes i know the ball joint boot is torn waiting on figs histeer arms. with the ball joints that you can replace nice feature
Old 09-29-10, 06:43 PM
  #230
sakataj
sakataj's Avatar
well now that i finally got my ls400 brake kit from redphoenix
https://www.clublexus.com/forums/sc4...ew-rotors.html
i have a few questions, i been reading this thread and a few others including these
https://www.clublexus.com/forums/sus...o-rubbing.html
https://www.clublexus.com/forums/sus...r-upgrade.html
and one of my ?'s got answered as to the bolts but i have another question.
i have rotora slotted rotors i got awhile ago and would like to keep them, can i use them when i mount my ls400 brakes?
i know ls400's are 12.4" rotors from reading his thread (the key info is my rotor size which i will measure tomorrow)
https://www.clublexus.com/forums/sus...y-auction.html
depending on the size of my rotora's, as in if mine wont fit after i measure them, will these work?if so is there a cheaper place to get them, like a vendor on here?
http://www.modacar.com/bolt-on/produ...539-21914.html
also....i been using hawk HP pads, any suggestions or preferences on pad brands for the ls400 rotors?
Old 10-03-10, 10:24 PM
  #231
BLKDOUT430
BLKDOUT430's Avatar
Subscribed ive been debating in doing this for some time now...I drive my GS430 hard and tired of warping my rotors and changing pads...besides the Lexus silver is peeling of my calipers so it gives me a reason to change them...lol
Old 10-04-10, 10:20 AM
  #232
2jzgttegs
2jzgttegs's Avatar
Default LS brakes
Originally Posted by PandaAE86
I'm sure many of you guys out there have seen IS and SC install LS400 brakes and also Supra TT brakes. Well, just for the record, the LS brakes DO NOT fit 2rd Gen GS!!!!
The following pictures will show what didn't fit.
btw, now they're up for sale. If you're looking for this setup for your SC or IS, PM me. I have the calipers and Rotora slotted & drilled rotors.
After looking at it for about 30 mins or so, I found a way to fit them. Very simply to do, no cutting or grinding required.
They do fit what you need is a SAGE RCA Kit. Contact member PHLM for info
Old 10-07-10, 09:17 AM
  #233
sakataj
sakataj's Avatar
so haven't forgotten bout this just been busy....tried to measure but left my wheel lock and tools at the house so i jacked it up our forklift (on the frame rails supporting the engine) and my heat shields are still on so i couldnt get a accurate measurement ....so eyeballing it, mine appear to be about 11 1/2" but im sure they actually are the 11.65" that the oems are so it appears i will be needing/buying new rotors for the LS.
so now my questions are...does any vendor on here sell Rotora rotors and what pads are you guys recommending for the LS calipers?
Old 10-07-10, 11:45 AM
  #234
LiCelsior
Retired
LiCelsior's Avatar
i used EBC red pads and they worked great.
Old 10-07-10, 02:06 PM
  #235
sakataj
sakataj's Avatar
thanks.....glad least ONE person who viewed this and has the LS400's answered me.
no squeaking noise overtime, my hawks tend to squeak at 1-5 MPH not when your hard on them and only after a year or so. the EBC hold up well? a lot or a little brake dust?
EDIT: just noticed you said USED as in past tense, do you not have them anymore or did you change pads?
Old 10-13-10, 11:51 AM
  #236
LiCelsior
Retired
LiCelsior's Avatar
i experienced no squealing at all even when it was a little cold. this is when u properly place break lube. EBC pads held up great and stopped great even in the cold. i would say there was a relatively low amount of brake dust but that all depends on braking habits.
yep i had a 93 LS400 which came with stock 2 pots so i upgraded for the 4 pot system and since i was getting rid of the car i removed them and its been sitting in the garage since, pads STILL looking new after being installed in March and removed in Sept. (Car and brake system for sale btw)
Old 10-13-10, 12:51 PM
  #237
sakataj
sakataj's Avatar
cool, i guess i will look into them the EBC reds and some rotora slotted rotors. guess i will be selling my gs430 calipers, Rotora rotors, and hawk pads shortly
while im looking and since i have never used EBC whats the difference in the EBC Red and green pads, which one is better?
also...cheapest place to find them, i found for both (EBC Reds and Rotora Slotted Pads) or even separate was here
http://www.modacar.com/bolt-on/index.php
Old 10-13-10, 05:10 PM
  #238
LiCelsior
Retired
LiCelsior's Avatar
EBC makes a couple of differ color pads, each varying the type of material and abilities. it ranks from green>red>yellow, yellow being probably almost race type.
i bought my red pads from eBay.
Old 10-13-10, 08:24 PM
  #239
shoganaina
shoganaina's Avatar
i love the scissor jack~LOL
Old 10-14-10, 04:58 AM
  #240
LiCelsior
Retired
LiCelsior's Avatar
i hate it, theres been so many times where it rolled over. they should provide wheel chocks.
Quick Reply: LS400 brakes do fit 2nd Gen GS!!
