View Poll Results: Would you be interested in having LS400 brakes on your 2nd Gen GS?
Yes, because it would be cheaper!!
55.56%
Yes, because I like the way LS400 brakes look.
22.22%
No, I still like Supra TT brakes better.
22.22%
Voters: 9. You may not vote on this poll
LS400 brakes do fit 2nd Gen GS!!
Old 06-13-11, 12:00 PM
  #256
starfyrels
Account under Legal Action - Banned
starfyrels's Avatar
^ Is that even safe?
Old 06-13-11, 12:46 PM
  #257
porn-adkt
porn-adkt's Avatar
LOL..Probably not..But he will find out.
Globalinx
IMHO the hack job on your suspension components is not worth the trouble of the mod. I believe the Proper LS4 bbk mod includes use spacers (Forget what they are called) im no Engineer, but i would not take the chance of reducing material and have it fail. Plus in addition How da F... are you gonna replace any of those pieces if they go bad, since you destroyed that hex nut and welded a spot.
Looks like your post should be re-named How not to install LS4 Brakes. Why not MK4 TT brakes? or a True BBK kit. There is many options, but yours should not be one of them
Old 06-14-11, 11:28 AM
  #258
Pnuge88
Pnuge88's Avatar
I have a question.. I installed my brakes the same time as i added spacers and wheels. anyone have vibration issues installing their brakes?
i have ichibi v2 spacers so i'm positive it can't be the spacers.. when i replaced to factory ISx50 rims they vibrated.. i put my sc stocks back on and they still vibrated. i have yet to try it without the spacer... the spacer fits exactly over the ls400 rotor with absolutely no problems.. as you can see in the picture the rotor sits perfectly on the hub. and so does the v2 spacer.. i get vibrations 40+mph. gets worse around 80+ i know the brakes are installed properly. what could it be??
Old 06-21-11, 11:48 AM
  #259
PHML
Master Thread Closer!!
PHML's Avatar
Is vibration at the brake pedal or the steering wheel?
Old 06-21-11, 11:53 AM
  #260
PHML
PHML's Avatar
Originally Posted by Globalinx
So, the calliper touches the "thingy" at the bottom of the suspension. Hard to explain, but you can kind of see in the following picture outlined in red circle. The point is that the calliper side rests on that thing and after shaving the bolt on the tie rod it will appear that there is a clearance. I am sure after some time after driving, vibrations will bend the aluminum on the calliper, and it will eventually slide towards the cut tie-rod bolt, perhaps causing damage to the calliper. It took me 10 tries at least to fit it on each side. When the tie rod was clear the side of the calliper would touch, as soon as I would take off a bit of material of the side, the calliper would engage the tie-rod. etc. The shaving shown on one of the pics below as well. I also put a small weld on the opposite side of the rod nut to prevent it from turning. Even though that there is a pin, the hole that its in is too large, and in case if things got loose the jagged and sharp edge of the cut bolt might turn just a bit even with the pin inside, and cat into your calliper fluid line.
Cost:
Freshly rebuilt callipers with cores: $380
Rotors and Pads $120
Fitting kit $60
_________
$560
Again, thank you all for your input, and I hope this additional info will help the future adventurers.
Wow!! Unbelieveable!!!
NOT SAFE...NOT RECOMMENDED!!
Old 06-21-11, 02:08 PM
  #261
sakataj
sakataj's Avatar
he hasnt posted in awhile, maybe something bad already happened to him...
knock on woods <hoping so>
Old 06-25-11, 01:39 PM
  #262
KingNasGS4
KingNasGS4's Avatar
That seemed like a hack job and pretty unsafe... What is the safest way to install LS400 brakes without RCA's? I can't afford to lower my car any more in this damn city.
Old 08-01-11, 08:55 PM
  #263
posdriftin
posdriftin's Avatar
couldnt you just run the 2ls lower ball joint like the ls guys so you dont have to use a rca? just wondering
Old 08-08-11, 08:19 AM
  #264
Globalinx
Globalinx's Avatar
Globalinx
Thanks for your kind words... Ether way, the set up works well so far. Had the car on a track (road course) several times as well, already. The car is being checked frequently (including my brake set up) for any signs of possible issues. I was advised against RCAs by my mechanics, as it is a crucial part of suspension, and the forces exerted on that adaptor might be too high during high speed turns and bumps. The part that we "chopped" is a part of steering (very important as well ) experiences only a limited amount of possible force, and was deemed safe by the people here, as there is plenty material left on that nut. It probably just looked scary from a wrong angle to some people on here. As far as replacing parts, there will be no issues, I was assured, besides cutting the new bolt and nut to fit again. The weld is just a spot weld (a small weld ball) made to hold the safety pin in place, incase things decide to unbolt themselfs.
On another hand, I had many issues with leaky callipers. It took me a while to get them properly done. I am also chewing through my rear brake pads extremely fast, I think its due to the fact that now the rear callipers receive more fluid pressure because of the change on the front.
Also if I had to do it again, I would definitely go with the MK4 TT brakes instead. It just so happened I heard someone on this forum had done the same thing and I got a good deal on this brakes. So I went ahead.
P.S. Is there any record of breakage? If anyone had done the same thing and had their wheels fall off plese post...
Old 09-22-11, 02:41 PM
  #265
emptyness
emptyness's Avatar
Originally Posted by tom steele
same damn caliper the supra ones are half steel which is heavier but if you look at the specs thats pretty much it besides the 1000 extra you spend lol
tom what kind of supercharger u running?
Old 09-23-11, 12:54 PM
  #266
sakataj
sakataj's Avatar
Originally Posted by LiCelsior
EBC makes a couple of differ color pads, each varying the type of material and abilities. it ranks from green>red>yellow, yellow being probably almost race type.
i bought my red pads from eBay.
i ended up trading my LS400 swap to save for a real BBK but i did get EBC reds for the OEM calipers.i hate my ebc reds ATM, i did the break in JUST as they said and they were fine for the first few fews, now they squealing like crazy at low speeds. im gonna try regreasing them and see if that helps
they do brake really well though i will give them that
jahnks8 (10-10-20)
Old 09-26-11, 02:20 PM
  #267
emptyness
emptyness's Avatar
i have a set of Ls400 calipers what else do i need to install in my 2003 Gs300?
Old 09-26-11, 02:43 PM
  #268
abounly
abounly's Avatar
^ RCA to help clear the lbj.
Old 09-28-11, 07:56 AM
  #269
sakataj
sakataj's Avatar
pads re-greased and loving them again ATM
Old 09-28-11, 08:09 AM
  #270
denut-L
denut-L's Avatar
Best $150 i ever spent so far on this car plus rca's of course. It looks sooo much better then the stock ones
Quick Reply: LS400 brakes do fit 2nd Gen GS!!
