View Poll Results: Would you be interested in having LS400 brakes on your 2nd Gen GS?
Yes, because it would be cheaper!!
55.56%
Yes, because I like the way LS400 brakes look.
22.22%
No, I still like Supra TT brakes better.
22.22%
Voters: 9. You may not vote on this poll
LS400 brakes do fit 2nd Gen GS!!
Old 03-11-12, 08:32 PM
  #316
Cartune
Cartune's Avatar
will is300 wheels clear LS brakes on GS?
thx!
Old 03-12-12, 07:08 AM
  #317
jtamulis
jtamulis's Avatar
100% no. I have a 2nd gen LS400, and I put the smaller brakes on it so I could run those rims.
they will NOT fit without spacers or something like that
hope that helps.
Jeff
Old 03-12-12, 10:30 AM
  #318
Cartune
Cartune's Avatar
What size spacers will it require?
Old 03-12-12, 02:39 PM
  #319
Sonic_RC
Sonic_RC's Avatar
Originally Posted by /209JOHN\
I just ordered a set of LS400 calipers
wild question: are the oem 2GS rear calipers alum also?
it'd be dope to polish the rears to match.
and yes, I read all 21 pages...lol
The rear 2GS calipers are iron. I wouldn't recommend trying to polish them as bare iron rusts very easily.. I remember I ground my rear calipers to clear my wheels and they had surface rust almost instantly.
I believe the IS300 wheels are 17x7 +50 and next to no brake clearance. So I would recommend like 25mm minimum
Old 03-21-12, 07:40 PM
  #320
Cartune
Cartune's Avatar
^ thx. another Qs, what offset (range) will clear LS brakes on GS without spacers. thx
Old 03-22-12, 10:50 AM
  #321
Sonic_RC
Sonic_RC's Avatar
offset doesnt really have anything to do with brake clearace its mostly spoke design. however on most one piece wheels the lower the offset is usually the more caliper clearance they have. Since the 2GS OEM 17" wheels are 8" wide I personally would not settle for anything skinnier (unless it was for a winter/snow setup). If you want a OEM Lexus 5 spoke style wheel that clears the LS calipers and no spacers I recommend getting the 3GS 18" wheels. You can get a set new (replica) for $500. Or get G35 rims
Old 03-22-12, 11:26 AM
  #322
Cartune
Cartune's Avatar
Thanks, thats good info.
Old 03-25-12, 12:36 AM
  #323
/209JOHN\
/209JOHN\'s Avatar
Thanks for the pointer . I guess I'm going the paint route now.
Old 03-29-12, 07:47 PM
  #324
kwags1023
kwags1023's Avatar
Default ls caliper
For all you guys that change caliper to ls have you guys had a problem with the brake booster?
Old 03-29-12, 08:00 PM
  #325
Wicked GS
Wicked GS's Avatar
No, I haven't .......
Old 03-29-12, 09:09 PM
  #326
kwags1023
kwags1023's Avatar
ok thank you
Old 03-29-12, 10:53 PM
  #327
PHML
Master Thread Closer!!
PHML's Avatar
None whatsoever.
Old 04-14-12, 05:38 PM
  #328
kwags1023
kwags1023's Avatar
Default Help! trying to look for a shop
Hello i'm trying to look for a shop around L.A. that can install my ls caliper, rotors and brake lines for my gs. thanks
Old 04-14-12, 08:03 PM
  #329
Sonic_RC
Sonic_RC's Avatar
any mechanic shop should be able to install them without any effort. But make sure you have the RCA's ready for him
Old 04-18-12, 07:05 PM
  #330
AirRideFan
AirRideFan's Avatar
hope that helps.
Jeff
What about the Supra Turbo brakes?
SAME THING, or are they many different OEM wheels that will fit on the 2GS w/ Supra calipers?
(with no spacers)
Not that 15mm spacers are a big deal to me, but if the Supra TT brakes on the 2GS can still work with 17"+ wheels, that would be cool.
Quick Reply: LS400 brakes do fit 2nd Gen GS!!
