View Poll Results: Would you be interested in having LS400 brakes on your 2nd Gen GS?
Yes, because it would be cheaper!!
55.56%
Yes, because I like the way LS400 brakes look.
22.22%
No, I still like Supra TT brakes better.
22.22%
Voters: 9. You may not vote on this poll
LS400 brakes do fit 2nd Gen GS!!
Old 09-18-14, 01:27 PM
  #376
Beaugs4
Beaugs4's Avatar
Originally Posted by xerojuan
hey guys, I'm looking for the smallest possible front ball joint spacer,
I live in SoCal now and if anyone has it in-stock where I can pick it up... that would be great!
i've been looking for the SAGE 18mm but I can seem to find a place that has them for sale.
please help!
Order one from SAGE directly, I just ordered one from him, easy to deal with and shipped quickly.
Old 09-18-14, 01:48 PM
  #377
xerojuan
xerojuan's Avatar
Cool.... how do I get a hold of him?
Old 10-24-14, 07:23 PM
  #378
RamAirRckt
RamAirRckt's Avatar
Anyone look at using an LS400 or LS430 spindle/knuckle on the GS or IS? Then it would easily and perfectly take the rotor/caliper the LS should have and should fit perfectly on the GS (or IS if you have one)
Old 12-09-14, 01:08 PM
  #379
EITELS123
EITELS123's Avatar
Default Ls400 upgrade and wheels done
I thought I would share some photos of my ls400 rotors and pads. I went with reman calipers and weaver rotors. I painted the rotors black just for fun. I know a lot of people around here have questions on what wheels to use/ or spacers. I decided a while back to move to 18's because my stock 17 was cracked. I did my research and found that the knock off 18x8 LFA wheels where cheap and would work if I with a LS brake swap. As far as the fitting the calipers I am running 30mm RCA's on the front and rear on stock suspension. I did have to cut the dust shield back to fit the calipers. So here are the pics:
Attached Thumbnails LS400 brakes do fit 2nd Gen GS!!-20141128_165318.jpg   LS400 brakes do fit 2nd Gen GS!!-20141209_131334.jpg   LS400 brakes do fit 2nd Gen GS!!-20141209_131345.jpg
Old 12-11-14, 11:05 AM
  #380
Miami-SC
Miami-SC's Avatar
I went with the Homemade rca's a member came up with, no issues whatsoever! Real simple too!
Old 12-11-14, 11:48 AM
  #381
hcharlesc3
hcharlesc3's Avatar
Originally Posted by Miami-SC
Attachment 349053
Can you break down what you did to run the homemade rca's?
Old 12-11-14, 07:05 PM
  #382
Miami-SC
Miami-SC's Avatar
https://www.clublexus.com/forums/sus...a-spacers.html
Hope this helps
Old 01-11-15, 06:33 PM
  #383
mikef
mikef's Avatar
Does anyone know the torque spec of the 4 bolts on the LS400 caliper when you separate it? It's a 4 star/hex bolts it looks like.
Old 02-05-15, 07:33 PM
  #384
gr8bryt
gr8bryt's Avatar
Ok, so I've read through the majority of the info in this thread. I appreciate all of the contributions, they really help a newbie such as myself. Here's my question: What would you all say about remanufactured TT calipers? I found a site that has them for about $100 per side, which seems to be a decent deal. I'll be upgrading to 19's on my GS by the end of Spring.
Old 02-05-15, 08:04 PM
  #385
Miami-SC
Miami-SC's Avatar
To me it came down to preference, I chose the ls calipers bc they looked better
Old 02-05-15, 08:12 PM
  #386
hcharlesc3
hcharlesc3's Avatar
I have remanufactured TT calipers and they work great. They basically rebuild oem calipers. I say go for it. Good luck
Old 02-25-15, 10:23 PM
  #387
gr8bryt
gr8bryt's Avatar
I'm running stock 16's now. Would I be able to keep them, or would I need to wait until I get my new wheel setup due to clearance?
Old 02-26-15, 03:58 AM
  #388
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
you need at least 17'' with spacer if your using stock wheels... 16'' are to small
Old 02-26-15, 05:24 AM
  #389
gr8bryt
gr8bryt's Avatar
Oh, ok. Thanks!
Old 04-06-15, 12:45 PM
  #390
gr8bryt
gr8bryt's Avatar
Well, after some deliberation I've decided to go w/ LS brakes. My pads are about shot so I figured this is a great time for an upgrade. I'll have to wait until the 15th to get my 18mm RCA's. I'll post some pics as things move along. I'm thinking of getting the calipers painted hyper silver or something along those lines.
Quick Reply: LS400 brakes do fit 2nd Gen GS!!
