View Poll Results: Would you be interested in having LS400 brakes on your 2nd Gen GS?
Yes, because it would be cheaper!!
55.56%
Yes, because I like the way LS400 brakes look.
22.22%
No, I still like Supra TT brakes better.
22.22%
Voters: 9. You may not vote on this poll
LS400 brakes do fit 2nd Gen GS!!
Old 02-19-20 | 07:43 AM
  #421
TrueGS300's Avatar
TrueGS300
I'm finally jumping on the LS400 front brake mod. Will post pics when installed. I went with a re-manufactured set of calipers, drilled/slotted rotors, just ceramic pads for street use, Megan racing 30mm RCA's, and Stoptech SS brake lines for the front and rear. Also will be moving to DOT-4 fluid and will paint the calipers with some nice Lexus logo stickers I found on ebay that are sized right for the LS400 calipers. Gonna look sweet.
Old 02-24-20 | 08:52 AM
  #422
gr8bryt's Avatar
gr8bryt
Originally Posted by n1ck
Finished the LS conversion a couple weeks ago. IS 18s fit perfect with no spacer.
Did you use EBC Rotors? Those look just like mine did when I did my brake swap.
Old 03-02-20 | 09:15 AM
  #423
AirRideFan's Avatar
AirRideFan
I like your photo's too... the stock 16's with the LS 4-pots look nice. But I'd ASSUME...100% chance he used EBC rotors, as they're the only rotors with that design (that I know of, at least) ha
Old 03-02-20 | 09:45 AM
  #424
AirRideFan's Avatar
AirRideFan
Originally Posted by IdleSerge
my question is, what RCAs are available? why are most 30mm when it seems like 17-18mm is sufficient? I'm on coilovers with bag cups up front so I can adjust to make up for that 1" drop if need be...
Thanks for the links... nice info. I suppose most use the 25 or 30mm RCA's because they get the ride height even lower, when on air... or allow the coilovers to ride nicer and still be even lower than you would. (since on the 2GS the Roll Center Adapters cause the car to drop as much as the spacer size- which is COOL)
Old 03-23-20 | 11:35 AM
  #425
SharifM's Avatar
SharifM
Like the look of your GS. I am in the process of doing the LS400 upgrade.
Old 03-25-20 | 07:27 AM
  #426
TrueGS300's Avatar
TrueGS300
Sharing my install.
Arussto (03-26-20)
Old 11-17-20 | 09:55 PM
  #427
enshiu's Avatar
enshiu
Originally Posted by EITELS123
I thought I would share some photos of my ls400 rotors and pads. I went with reman calipers and weaver rotors. I painted the rotors black just for fun. I know a lot of people around here have questions on what wheels to use/ or spacers. I decided a while back to move to 18's because my stock 17 was cracked. I did my research and found that the knock off 18x8 LFA wheels where cheap and would work if I with a LS brake swap. As far as the fitting the calipers I am running 30mm RCA's on the front and rear on stock suspension. I did have to cut the dust shield back to fit the calipers. So here are the pics:
Is this a straight fit?
Old 11-18-20 | 08:47 PM
  #428
firelizard's Avatar
firelizard
Bro.
Never mind the rest of the thread, you didn't even read the entire post you're quoting.
There is not a single unanswered question about LS400 brake swaps. Please read the information that people took the time to write for the benefit of people like you.
Old 05-11-21 | 09:57 AM
  #429
AhsanZB's Avatar
AhsanZB
does anyone know if the 2017 Lexus IS350 F Sport wheels would clear the LS400 BBK? I know the 3GS 5 spoke will clear and it is about the same specs.
Old 12-10-22 | 09:37 AM
  #430
Choppz's Avatar
Choppz
So what do we need to upgrade the rear?
Old 12-15-22 | 11:24 AM
  #431
gr8bryt's Avatar
gr8bryt
No need to upgrade the rear at stock power levels. The LS brakes do help a little, but pad choice will give you better feedback with this upgrade.
I used FIGS 15mm (could be 18mm) for my RCA's, gave it just the right amount of drop on stock suspension.
Regarding the newer IS style wheel, I'm not sure about the clearance. IF you can measure the wheel from the hub mount to the back of the spokes, that may help.
I have found that most concave wheel designs will clear the 4 pot calipers.
jdog0411
10-05-11 05:19 PM
jaysee
GS - 1st Gen (1993-1997)
06-22-11 10:49 PM
status....
Suspension and Brakes
13
06-13-09 10:26 PM
rawdil49
01-26-08 11:25 PM
PJ
06-17-05 06:25 PM
