View Poll Results: Would you be interested in having LS400 brakes on your 2nd Gen GS?
Yes, because it would be cheaper!!
55.56%
Yes, because I like the way LS400 brakes look.
22.22%
No, I still like Supra TT brakes better.
22.22%
Voters: 9. You may not vote on this poll
LS400 brakes do fit 2nd Gen GS!!
Old 02-17-05, 07:31 AM
  #61
HKGS300
HKGS300's Avatar
Originally Posted by GammaLex
Supra on top Ls400 on the bottom. WE need ls430 brake pads.
Gamma ... you're wrong
Old 02-18-05, 10:11 PM
  #62
PandaAE86
PandaAE86's Avatar
are you sure? the bottom sure look exactly like my LS400 brake pads
Old 02-18-05, 10:14 PM
  #63
One HoT
One HoT's Avatar
I'm pretty sure that the LS4 pad is on the bottom..I have that gap btw the pad also..
Old 02-19-05, 12:35 AM
  #64
HKGS300
HKGS300's Avatar
this is the KS400/UCF20 pad.
Old 02-19-05, 12:36 AM
  #65
HKGS300
HKGS300's Avatar
This is the Supra TT pad
Old 02-19-05, 12:41 AM
  #66
HKGS300
HKGS300's Avatar
That gap that divides the pad area in 2 is just a brake pad type characteristic... some people will claim that the gap will improve the pad's resistance to fading (the friction material has more space to expand when hot).
So the LS400 pad can no or one gap depending on the pad design. The important part is the backing plate ... that will determine if you can mount the pad into your calipers
Old 02-19-05, 02:01 AM
  #67
Cannonbear
Cannonbear's Avatar
so is there much difference in terms of stopping power from ls400 to ls430 brakes? will sc430 wheels clear the entire LS setup?
Trying to figure out whether to lower my car with coilovers or do this brake upgrade, but i know the lexus BBK won't clear gs 17s so i'm stuck there.
Old 02-19-05, 02:14 AM
  #68
LasVegasGS
LasVegasGS's Avatar
So when are we gona get a full wright up on this DIY we need a DIY page on CL that would kick *** like bananaGS website but with more then 1 person adding info would be great.
Awsome work
Old 02-26-05, 07:07 PM
  #69
LasVegasGS
LasVegasGS's Avatar
So whats the Trick anyone wana tell us already?
Old 02-26-05, 09:17 PM
  #70
PandaAE86
PandaAE86's Avatar
It's just a 1/4 inch spacer that goes underneath the hub/knockle. Which will help lower your car 1/4 inch without adding anymore camber to it. I'll take some pictures soon on how it works and what it looks like.
Old 02-28-05, 01:42 AM
  #71
HKS_GS430
HKS_GS430's Avatar
thanx big guy
Old 02-28-05, 11:30 AM
  #72
LasVegasGS
LasVegasGS's Avatar
Thanks Panda that would be sweet
Old 03-05-05, 11:14 PM
  #73
Cannonbear
Cannonbear's Avatar
any update on the pic?
Old 03-23-05, 06:25 PM
  #74
PandaAE86
PandaAE86's Avatar
here are some pictures of what the spacer look like and where does it go.
I made the protype with wood, so that I can take the measurements.
If you have any questions, feel free to ask.
No, this spacer will not fix your camber.... unless you have adjustable coil overs and Yes, it will lower your car however thick the spacer is. In the picture, I used a 1/4 inch thick wood, but the aluminum one that I made for my car is 1/2 inch thick.
Good Luck everyone
Old 03-23-05, 07:10 PM
  #75
johnee78
johnee78's Avatar
Good Luck everyone
The roll center adapter will straighten out camber because I have it on my car and the before and after camber adjustment is all the proof I need ..Because by installing this you actaully raise the steering knuckle instead of bringing the car down to lower it..this adapter is better suited for those who have coilovers because the front will be lower than the rear...
Quick Reply: LS400 brakes do fit 2nd Gen GS!!
