View Poll Results: Would you be interested in having LS400 brakes on your 2nd Gen GS?
Yes, because it would be cheaper!!
55.56%
Yes, because I like the way LS400 brakes look.
22.22%
No, I still like Supra TT brakes better.
22.22%
Voters: 9. You may not vote on this poll
LS400 brakes do fit 2nd Gen GS!!
Old 12-06-07, 03:55 PM
  #121
exquisit
exquisit's Avatar
gsteg: thanks for answering that... i just wanted to check how off the bias would be but it seems that its within reason
did the ls400 or supra brakes need any special mounting brackets? apart from the rca
and did they affect the abs in a negative way??
Old 12-06-07, 04:13 PM
  #122
GSteg
GSteg's Avatar
The LS400/supra brakes do not require any mounting brackets to fit. They are a direct fit as far as mounting location. Only the LS400 calipers need the RCAs. The Supra will fit without it. But you need to make sure you have the right wheels to fit the wide calipers. If you run OEM wheels, you'll probably need a 15mm spacer upfront to fit. If you have aftermarket wheels, make sure they are high-disk type.
The ABS function is not affected because our sensors detect lockup, not brake force.
Old 12-07-07, 01:13 AM
  #123
kit cat
kit cat's Avatar
Originally Posted by Nosexnolex
when doing this swap, supra brakes or ls400, do you guy change MBC (master brake cylinder)? what about the brake balance front to rear? do u also install brake balancer?
p.s. supra tt brakes were made by sumitomo. its a company that makes brakes for race cars and race bikes. this is why the only car to beat the supra from 70-0 is a carrera gtJ guess whom work on it's brakes? supra brakes are way ahead of the ls400 no question about it.
Sumitomo also runs a huge bank in Japan. Also a huge trading company. They pretty much own a company in every commodity. google "zaibatsu" and you'll see what I mean.
but back on topic, I thought LS brakes were aluminum monoblock unlike the JZA80. So wouldn't it better? And I think balance will be off if you just do fronts.
Old 12-07-07, 05:16 AM
  #124
Nosexnolex
Nosexnolex's Avatar
I have to look at the back of the caliper to check for correct spelling of the name.
Old 12-09-07, 10:47 AM
  #125
j0xxx
j0xxx's Avatar
it ooks like the ls400 pads cover more surface area
i like
Old 12-10-07, 12:36 PM
  #126
dw1628
dw1628's Avatar
any other update with new installs, i want to see the "how DIY" thread !1
Old 12-10-07, 04:55 PM
  #127
FinLIFE
FinLIFE's Avatar
Just got mine in today. In case anyone wants to know a total of two LS calipers with pads weighs in around 24-25lbs. So one caliper loaded with pads is right around 12lbs. Now I have to decide whether to powdercoat them or get them polished..hmm
Old 01-08-08, 11:24 PM
  #128
Tank
Tank's Avatar
Hey guys, excuse the rookieness but are those LS400 BB available for the rear as well?
Old 01-29-08, 07:17 PM
  #129
rw3
rw3's Avatar
Check out using the new IS or GS Brake Calipers. They are aluminum monoblock and will be a direct bolt on. They also are the same size as that of the Supra. Also, the stock Supra pads are great at not fading the road course in a BPU++++ Supra going from 130-45mph turn....
Old 01-29-08, 07:23 PM
  #130
GSteg
GSteg's Avatar
the 2IS and 3GS calipers are not bolt-on.
Old 01-29-08, 07:50 PM
  #131
rw3
rw3's Avatar
Wanna bet? I've got a Master Lexus Tech that says otherwise.....
Old 01-29-08, 07:54 PM
  #132
kit cat
kit cat's Avatar
it should fit with minimal mods but I don't think its a bolt on.
this is what you need.
courtesy of Night-Pager.
Old 01-29-08, 07:58 PM
  #133
GSteg
GSteg's Avatar
And we have a few master tech on this forum who already looked into it.
The mounting holes are not the same as our cars, therefore it's not a 'bolt-on'. I'm sure you can make brackets to have it work, but then again, you can make brackets for anything.
Old 01-30-08, 05:31 AM
  #134
aliga
Former Sponsor
aliga's Avatar
Just installed a set of ls400 calipers on my gs400 with the stock gs rotors. Stopping is night and day compared to before. I had to cut a few threads off the tie rod stud, and also had to shave a little bit on the caliper near the stud area. Also had to cut a little portion of the dust shield.
Now I brake in confidence.
I have a set for sale if anyone is interested, 210 shipped for a set of calipers with pads, shims, etc.
Old 01-30-08, 07:17 AM
  #135
gcam77
gcam77's Avatar
Can ls400 calipers work with stock gs300 rotors?
Quick Reply: LS400 brakes do fit 2nd Gen GS!!
