Bushings & Bushes. Whatever, mine are Bad!
#46
Originally Posted by mungrin
I replaced only my lower control arm bushings as those are the ones that are prone to fail on any double wishbone suspension.
#47
I replaced only my lower control arm bushings as those are the ones that are prone to fail on any double wishbone suspension.If you have the money,you can change em all and you car will basically ride like a brand new car.
If it took 11 years for the front lower arm bushes to virtually collapse, what condition are the other bushes in? After checking them all we found slop in all the upper arms and rear suspension links, each one had excessive movement due to the rubber losing it's properties. No one bush had failed/split like the front lower ones but add all that play together and the suspension is going it's own way allowing the wheels to swing in the breeze.
Now Yakuza has all new suspension bushes the car is transformed, tighter, smoother, quieter and the ride is so much better despite running on low profile tyres which transmit more harshness from the road surface. The handling/steering is also improved now that the suspension uprights are better located and will not flop around under load.
So dont wait for the clunks to set in, if your car has some years/miles on it replace all the suspension bushes and get back the ride quality that was there when the car was new.
#48
Hey Guys,
I'm new to this site, but not new to Lexus. I bought '92 SC400 new, now I've got 180K miles on it and have had almost every problem I've seem on this site. But I'm old and a little slow, so I need to understand this LCA thing. I need new rear
control arms or bushings. Can I use the Supra stuff or do have to go OEM?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#49
Originally Posted by pudieinpa
Hey Guys,
control arms or bushings. Can I use the Supra stuff or do have to go OEM? ![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#50
I noticed something whilst looking for pricing on the Supra LCA's. The 93-96 LCA's are about $200, while the 97-98's run around $350. I'm assuming they have different part numbers....anyone know the difference between these two sets of arms?
#51
I think the 93.5-96 are cast iron and the 97-98 are aluminum????
(Someone correct me if 'm wrong)
Go with the 93.5-96's....better value and pretty much the same thing. I am going with those too on my 1998 SC400. Should handle a bit better but you can feel the bumps a little more. Bushings in the Supra LCA's are thicker than the SC's but still rubber. Hope this helps.
#52
does anyone know if these oem bushings will fit 94 ls400 ?
thanks
thanks
Originally Posted by autiger200
There is one more option...Lexus now sells the OEM control arm bushings
Bushings are made for `97 and up SC, but fit all model years. There are two different bushings for the LCA, the front and rear, with different numbers. Youll need one of each for each side.
Front: 48654-24040
Rear: 48655-24050
from Eurojulian (I believe...):
"It is official now. I instaled my ctrl arms with `97 bushings today in `92 SC4. It was drop in fit. No problems whatsoever. Car rides incredibly with new stuff. Only after I removed ctrl arms I saw how battered were old bushings only after 90k miles on good Florida roads.
As I said in earlier posts, rear bushing was redesigned and beefed up, so it should last this time and it is well worth the money. Thank you Lexus"
Cant find the thread this came from, for some reason, but Im sure another member can add to this...
Steven Lee
92 SC4
Front: 48654-24040
Rear: 48655-24050
Steven Lee
92 SC4
#53
i think i have this same problem with my sc.. i have a lot of noise and i have silkroad coilovers on my car.. the car has a huge drop.. but lately its been squeaking a lot.. the car has 183,000 miles and these bushings are stock.. Are these the same symptoms you guys are having? At first i thought it might have been my bumpstops but then i stumbled on this thread.
#54
i think it was previously mentioned in this thread, but it was also in a magazine's how-to a while back. . .
lowering your suspension too much is detrimental to your handling. not old are the control arms not working like they are supposed to, but they are taking the weight from angles they aren't meant to...consistently.
I'm guessing this will fatigue parts much faster.
i can't remember, but i thought the article had how to go lower(adjust other suspension components to work)
i wish i still had the magazine
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#55
After I do all new rotors/pads in the spring, new LCAs are my first priority... Ive decided it'd be best to just buy 2 LCAs at 360 each and have them put in. This bypasses the need for labor to burn the old bushings out, press new ones in. It also gives me new balljoints, which would probably need replacement now anyway.
So brakes, LCAs, engine/tranny/steering rack mounts, amplifier. Lotta money needed.
#56
#57
Originally Posted by mikeloc24
Jay, why not just buy them for $190 each from Carson Toyota and save that extra $340 for something else?
190 reflects the price for supra LCAs, right? There is a difference between the two in ride quality and such.
#58
Tired of the car with the mind of its own when I hit a bump so looks like I am taking the Supra LCA route as well. Will call Carson tomorrow, but do I need only the lower. They offer front upper and lower and make sure I do not leave something out and the problem persist.
#59
#60
