98GS300 Lower Ball Joint came off???...Question ?>=/
[QUOTE=T.L.W.]
Can i ask what car you drove before this ??
A 2001 suburban. I wanted to get a lexus is because I was paying to much for gas. So, now my car is just sitting at home and i'm now using the burban again. I feel safer driving my suv eventhough i'm spending more money on the gas.
ball joint failure
I had the same problem as everybody else...driving down the road and the ball joint seperated from the the lower control arm......screwed up my fender and so on....had to replace the part on site just to move the car...not fun..but solved the solution...still...how do you get those lights to come off...vsc,abs and so on....someone in the beginning of this thread said that it would cost $855 in parts...is this true??????? or is there a simplier suggestion......thanks..Paul...98 gs400...with 20's....also...what does it require to bleed brakes on these cars...the maual I borrowed from the dealership says you need a computer????????
i have a 98 also and the same thing happened to me or actually my boyfriend while he was driving it...does this year have some kind of recall for this??? my lights are on too...and my fender got pushed up. ....
Originally Posted by stevechumo
I don't think it's a recall or anything. In my case, I need the ball joints because I tore its dust boot while trying to remove it so I need to replace it. Otherwise, it should stay there for a long time. In your case, you may jack up your car to check if the ball joint jam nut is still attached. Also, check for its clip that's inserted through the nut and bend it to prevent the nut gets loose.
Originally Posted by corkycal
how do you check to see if the lower ball joint needs to be replaced?
we need detail instuctions please. what to look/feel for..
how much is the part?
thanks
thanks
whew...glad i was able to replace my passenger side lower ball joint before it separated!!!....it didnt take long but my symptoms were throwing me off...groaning noises, shimmy, and clicks...i thought i may need an alignment or bushings...it occured to me reading through the forums that the ball joint itself may be bad. I checked it and it didnt seem bad until i started taking off the brake caliper and saw the upper arm move up an inch before the lower arm started to move!!! the whole operation took around 30-40 minutes for one side with standard hand tools, no power tools. it helps to have a half-inch drive 18 inch breaker bar thanks for all the info from the forum members...lataz oh yeah parts cost...9.99 for puller, 104.00 and some change for the ball joint from lexus dealer. 1999 GS300
Lights are on.
i got it fixed already but my lights under the gauges are on now!!! Any advice as to how I can shut those off??? BTW my horn all of sudden stopped working too...= \ >thanks
Will
P.S.
Why are your posts in magenta? LOL
