98GS300 Lower Ball Joint came off???...Question ?>=/
#31
GS300/400 Ball Joint Recall
Guys and Gals,
I'm new to this forum, but I just saw this thread. I believe that the front ball joints have been recalled on all GS300/400 up through 1997. I didn't see it listed for 1998, but here is the link for the 1997: http://www.recalldata.org/1997/32348.shtml
I have a 1994, and it is recalled as well.
The ball joints are inadequately lubricated and can separate. This sounds exactly what you guys are having problems with. I just caught mine in time, or the same could have been a result. Everybody should get this taken care of, especially something this sever. I would start contacting lexus on this one for the '98 model year. Given the fact that all GS had issues up to this date, then there is a good possibility that there were still problems in early dates of the model year. As for all of the other damage, I would pursue reimbursement from lexus. Take it further if necessary. This is a pretty serious defect for lexus.
Let me know what you guys find out!
#32
Originally Posted by TAMR_GUS98
If the lights came on after the ball joints were replaced, then they might have damaged the wheel speed sensor. On the horn, it might be a blown fuse.
Will
P.S.
Why are your posts in magenta? LOL
Will
P.S.
#33
You Go Girl!!!!!!!!!!
Originally Posted by GS4_on_20z
thanks for your help...i 'll look into that..btw...i LIKE magenta! = ) Its a girlie color!
Will
P.S.
Let us know how your car comes out.
#34
Always happy to help. Judging from your avitar, I kind of thought you were a female but was not 100% sure. Anyway, the color just makes your posts stand out. Interesting.....
Will
P.S.
Will
P.S.
#35
That's Cold.
Originally Posted by stevechumo
A lady on the forum is always nice. But who knows that's a *******...Just kidding.
Will
#36
OOOOhhhhhhh!!!!! That's cold hearted Steve. But you never really know, huh?
Will
Will
#37
Originally Posted by gs4rocks
I had same problem last year.
I had noise from the front suspension, and took the car to the dealer.
The dealer kept the car for one whole day, and told me there is nothing wrong with the car.
I took my car to Midas next day, and they found both front lower ball joint cracked and loose.
It took them 5 min to find the problem.
I took the car back to the dealer to replace them under warranty.
Is there ball joint in the rear? If so, I need to check those as well.
#38
More Questions
Regarding the replacement of the ball joints I have an additional question. It seems that lexus is doing this quite regularly (Ball joint replacement). But in addition, they are also they are recommending replacement of the lower control arm as well, because those rubber bushings are beginning to rot or degrade. The cost is $193 per side!!
My question is although my warranty is expired, should this be covered by Lexus?? Or is it simply a wear item I have to pay for?? HAs anybody had them replaced by the dealer at no cost??
Thanks for the replies.
Doug
PS-I understand as well that there is a polyurethane replacement for this bushing. Does anybody know where to source these?? And there cost??
Doug
#39
It's funny - I just got off the phone with my dealer in Bellevue and they "can't find that recall"
I sent them the below link as well as the exact same info from the NHTSA web site...I have a '93 so hopefully it's not too late if , in fact, they agree that the recall exists...
http://www-odi.nhtsa.dot.gov/cars/pr...ls/results.cfm
#40
#43
balljoints
Originally Posted by cliffud
we should make this a sticky... it could potentially save lives.
I seriously recommend anyone with a 98-2000 GS have their balljoints checked out if you haven't already...
I also hope those Daizen control arm bushings are released soon cuz those are next on my maintenance priority list!
#44
Former Vendor
Toyota Recall of SUVs/Trucks... same prob as GS?
Check out this news article that came out today!
http://moneycentral.msn.com/content/...1.asp?GT1=6469
Toyota (TM, news, msgs) said the truck and SUV recall covers 774,856 vehicles in the United States, including the 2001-2004 model years of the Tacoma, the 2001-2002 versions of the 4Runner and the 2002-2004 model years of the Tundra and Sequoia.
Toyota said the surface of a ball joint which connects to the front suspension may have been scratched when it was manufactured, which could lead to wear and tear over time.
Any excessive wear or looseness in the joint could force drivers to exert more effort when steering, allow the vehicle to drift and increase the amount of noise from the suspension.
#45
You can check them yourself using a pair of very large Channelock pliers; with the car supported under the control arms, wheels off, you then squeeze the balljoint from top and bottom, any visible compression of the assembly during the squeeze would be a bad balljoint.
