Air Runner Vs. EAI
Old 01-05-05, 05:27 PM
gee es
gee es's Avatar
Default Air Runner Vs. EAI
I have been researching on what kind of suspension to use. My goal is to lay frame, like the black GS400. He is running EAI suspension. I'm basically asking if anyone knows how low the Air Runner suspension will go. Will it lay frame like the EAI setup?
Old 01-05-05, 10:23 PM
rominl
exclusive matchup
rominl's Avatar
what is eai? i thought that's air runner he has there already
Old 01-06-05, 01:41 PM
gee es
gee es's Avatar
He has EAI installed on his GS.
https://www.clublexus.com/forums/sho...ght=air+runner
Air Runner installed on his LS.
Old 01-06-05, 09:08 PM
rgarjr
rgarjr's Avatar
EIA are are air cylinders from The Hack Shack.
Air runners are 100 times better than air cylinders because they are designed for a car's suspension as opposed to air cylinders which are used in machinery.
Of course air runners are so expensive it is just ridiculous. Also you can't even just get the struts you have to buy the whole kit.
Old 01-06-05, 09:50 PM
rominl
exclusive matchup
rominl's Avatar
Originally Posted by gee es
oh when you said black i thought you meant panda. panda has air runner on his gs. it's so much better
Old 01-06-05, 11:37 PM
rgarjr
rgarjr's Avatar
Does Panda have any pictures of his air struts?
Old 01-07-05, 02:24 AM
aloha08isf
aloha08isf's Avatar
air runners are no doubt the best if you want to SLAM! but they are soo damn pricey....I heard with the air runners...its like all the good stuff from coilovers and airbags put together.
Old 01-07-05, 08:56 AM
rgarjr
rgarjr's Avatar
The main purpose of having an air ride suspension is to slam the car so low that you can tuck the upper part of your wheels.
I believe the other day I called the wheel shop out there in Bellflower, CA and they quoted the kit to be around 4300.00. I think they should consider selling the struts alone and getting your own air valves, maybe Parker or SMC on your own.
hinoki
04-29-20 01:22 PM
JHutch1986
05-16-19 02:31 PM
ReeM
11-27-16 11:21 PM
ReeM
Suspension and Brakes
11-22-16 07:10 PM
shikbas
RX - 1st Gen (1999-2003)
01-28-05 08:28 AM
Quick Reply: Air Runner Vs. EAI
