should i get daizen sway bars?
I'm getting l-tuned springs and shocks for my gs430 - with them already installed, should I just replace the sway bar bushings with daizan bushings for like $30, or is it worth it to shell out $500 for the complete sway set? I guess what I'm asking is - is there going to be a significant difference in flat cornering between l-tuned suspension and daizen bushings vs. l-tuned suspension and complete daizan sway set??
Thanks
Thanks
Thanks
Thanks
is their a diff , night and day
do a search on daizen sawys and you will see lengthy threads and reviews
my advice , if you drive even slightly aggressive , ltuned shocks and springs will not cut it in the least
The One
Although better than stock, there is still some body roll with the L-Tuned setup. Sways will clear that right up. I had the TRD sways when I had the L-Tuned S/S and there was a little jiggle in the rear end that some bracing fixed. I can't say for sure that the Daizens will be better with this aspect since I did not have the L-Tuned/Daizen combo. Even if it does, nothing a little more $ won't fix.
You might want to PM PHML. I believe he had the Daizen bushings and now has the full sways. He can probably answer your question directly.
exclusive matchup
i too had trd and now daizens. i love how the daizens ride smoother but the handling is still as good. yes the bushings are just 30 bucks, but imho i would just save up those 30 bucks as well and just wait until i can get the sways bars. do it once and do it right. you will not regret
Romini - so would you recommend the daizens over the trds? I was thinking daizens but I've been reading a few places that indicate the daizens have problems with coming loose and also squeeking - so now I'm kind of thinking trds. Any opinion on this?
i was not a believer in sway bars and what they could do, until mine were installed and noticing the difference was right away from me. well after i got them in the tightest setting later i really noticed the difference. great bars from everyone i know and have read here and i agree..
exclusive matchup
about the screws and stuff, i don't know, but my install never had any problems,and it's been more than 1 1/2 yr of daily driving. for trd, they had their shares of problem like broken end links so missing bolts too.
where to buy
Now that it's decided that's Daizen sway's are the way to go, where is the best place to buy? Not necessarily the cheapest but the best for service, price and follow up if needed?
The One
He is a Daizen dealer and has installed many of these including the ones on my car. If you have questions on the product and install, he'd be the one to contact.
http://www.tmengineering.net
todd@tmengineering.net
exclusive matchup
Originally Posted by Neo
Todd at TM Engineering.
