EDFC Installation Question
As I was looking through the intructions for the EDFC, I noticed that it does not mention where you are to set the damper before you install the motor. Does anyone know where I should set my damper prior to installing the motor? Any help is much appriciated.
-Thanks,
Nick
-Thanks,
Nick
I'm not certain but I don't think it matters because I believe the EDFC calibrates itself the first time it's powered up.
Originally Posted by beaterKU
So do the motors have a the ability to stop themselves once they reach setting 0 and 16? The instruction are very sketchy on this.
Thanks
Nick
Thanks
Nick
So you can install the motors without regard to the damper setting and the edfc will determine where it is. My only fear is the motors will go beyond setting 0 or 16 and damaging the shock..
-Nick
-Nick
The motor is not that strong to go beyond 0 and with the way it callibrates itself, it should not go beyond 16 either.
Manually, it would be hard to go beyond 0. I guess you might be able to torque it REALLY hard to make it go beyond 0 but I'm not going to test it out. You can go beyond 16 (again manually) though and Tein does warn about this situation. This is why the EDFC goes to 0 first before setting the other numbers when it is started up.
Thank you very much for your info. I am going to tackle the install when it thaws abit around here. Not thinking, I let my car outside with the cover on and it sleeted with a bit of freezing rain 2 weeks ago and has yet to make it above feezing since. Hopefully it will tahw soon.
Thanks again,
Nick
Thanks again,
Nick
Thanks again,
Nick
Thanks again,
Nick
but like others have said, it shouldn't matter cz' the motor will just turn the coilover all the way back to 0 (stiffest) when it starts up and count from there
techsc400
Suspension and Brakes
12
10-31-07 05:51 PM
