Daizen Front Camber Kit installed
Originally Posted by RADSC
If your wheel/tire combo is rubbing now, most likely it will rub after the camber correction.
good luck.
good luck.
my tires wud prolly last 6-7 mos....i suppose that is bad......
Originally Posted by indypwr
mine does not rub at all but im concern with negative camber on all four sides.
what is your camber set at now?
RADSC how bad was your camber before you the camber kit on. i just did the tokico illumina setup w. Mkorsu a few weeks ago and i can see some negative camber on the rears. I'm running a fairly conservative 225/17's all round so i'm not rubbing. I have the Supra LCA's in my room waiting to be put on and the daizen camber kit (front and back) in my room. the LCA's have to be switched, but i don't know if i have the money to put on the camber kit.
idelible- i thought i could put on the camber kit too, but it involves replacing the upper control arm bushings. not exactly the easiest DIY job.
here's a pic of the rear drop
SC300_704
Suspension and Brakes
27
10-27-08 02:07 PM
