Thinking about Supra brakes...
Is this a good deal over at Supra Forums?
http://www.supraforums.com/forum/sho...ghlight=brakes
Anything missing that he doesn't mention that i would need to think about?
How easy is the swap?
Northern California Regional Officer
I assume you know that you need supra size rotors to go along with the calipers.
The rears are not bolt on.
You would need to make a custom bracket to adapt the mounting holes of the rear caliper. Take note that this bracket needs to be designed and built to withstand the stress factors of the whole caliper assembly or else.
Originally Posted by LasVegasGS
I've also been thinking about doing this to the fronts but I've read that people where haveing trouble bolting supra brakes onto the GS are you 100% they are bolt on if so I'm all over it.
You also need to make sure your wheels will clear the brake calipers. Many don't.
Also, if you have a stock tire for a spare, you better check that as well or you'll be in for a very un-pleasant surprise.
Lot's of Supra TT spacesaver spare tires selling well on the classifieds as well.
Lot's of threads on these topics.
Any idea if they will fit under an Ltuned 18's?
Also Supra N/A and the Supra TT brakes are diffrent right? the Supra TT is what I want
I think Neo knows the answer to that.
Otherwise PM me your e-mail for a PDF file of the template I made.
Think you can send me that PDF file too..
areza323@worldsavings.com
Originally Posted by rominl
i doubt that. the ltuned fit just barely over the ap racing, and i believe the supra tt brakes are even a tad bigger
Surprisingly, the Brembos apparently fit behind the Salinas as someone did that in San Diego and he said no spacers.
FYI - StopTechs and Rotoras will also fit behind the Salinas.
CinFulxGS4, I'm not sure if you will need new wheels again if you attempt the TT upgrade.
Originally Posted by Neo
LOL. The guys from NorCal all know the tests we've done. RMMGS4 sold his TTs before we could do the test fit but we tested the Salinas on his APs. It barely fit and would need a small spacer to be safe. From that we concluded that the Salinas won't fit with the TTs because as Rominl said, the TT capilers are a little bit bigger than the APs.
