Lowering Springs for SC400
Have any of you ever used Tanabe NF210 springs (which is made specifically for SC300) for your SC400? The manufacturer advertised they will lower the front 1.0" and the rear 0.4". However, my SC's rear lowers 1.5". I gotta use the whole OEM bump stop so that it'll raise the rear another 0.5" to be leveled with the front. Do you have any same problem as mine? Please let me know. Thanks.
Originally Posted by /Aerostar\
NF210 springs arent madefor SC's, just Supras I believe. If you got the Supra ones, then they will lower the supra 1"/.4", but will lower the SC about 1.7"/1.1" ...
Once this is donem your car should even out.
Rob
Originally Posted by sc400texas
You will need Supra Struts to run a supra spring. If my knowledge is correct, the supra struts have a different spring mount than the SC struts.
Rob
Rob
SC springs + SC shocks = Advertised drop for SC
Supra springs + Supra shocks = Advertised drop for Supra plus ~.7"
SC springs + Supra shocks = Dont work
Supra springs + SC shocks = Dont work
SC Tanabe springs
Originally Posted by jeremyp111
Where did you buy NF210 springs for a SC400?
ultimate
Suspension and Brakes
05-24-13 03:04 PM
rodolfo400
11-15-12 11:30 AM
