Opinions on big brake caliper colors??
#46
Originally Posted by ebruce2
put in my vote for either color-matched (1CO) or goooooooold! Then your ride will be toight like a toiger!!! Sorry.
i like color matched
or black
#47
Originally Posted by TTurboPimp
Very well put Neo, and I could not agree more with everything that you said. If you talk to all of the BB guys, the ones that will impress you the most (or at least me the most) are the Stoptech guys. Stoptech seems to put more emphasis on proper brake bias on a car by car basis, then anyone else that I have spoken with. I know there are guys that are running Stoptech on all 4 corners.... Stoptech told me tonight, and many other times that this set up is not optimal for the GS. There exact words were, its great for looks....but the bias would be way out of whack with too much in the rear. On the other hand, I know one of the GS guys running this, and he loves! There is always a way to get a four way kit to fit that is made for another car, but is it the right thing to do.....that is the real question. Im gonna have to think that the dude from stoptech, who pulled out all of the spec and test sheets, knows a little more than me.
#48
Originally Posted by rominl
very true jeff, can't agree more with what you, neo, and ed have said. in fact i still remember one article posted up long time ago where stoptech rented an airfield or something and did braking testing and balancing on the 350z (i believe) and the results, and how they analyzed the results and how they choose what brakes to use on the car. it was an extremely impressive article imho.
#49
Originally Posted by T.L.W.
#50
#51
Originally Posted by Indio
Four pistons vs. two or six pistons vs. four will be more efficient at what they do, what they do being the key, front brakes carry about 65% of stopping duties and without a proportioning valve to adjust brake bias a bigger/better setup on either axle will only perform it's percentage of braking duties better, too much brake out back will cause problems up front, and Jeff I vote for the Stoptech's in black.
#52
actually pistons count aside, i think the amount of pistons areas is more important. having 4/4, 6/4, or 4/2, it'a more about how much pistons area you are putting on, and that should affect greatly on the braking power
#53
You took the words right out of my mouth.......nto all 4 piston brakes are alike, not all 2 piston brakes are alike, and the same for the 6......the manufacturers make these things with different size pistons .......in Stoptechs case, to match them up on a car by car basis. If Stoptech recommends a BB upgrade for fornt only, you can believe that they are matching that 4 pot fornt system to be ideal with stock rear brake calipers.
A Dodge Viper 4 pot, will not be the same as a Civic 4 pot.
By the way, I am going with the Stoptech 355 fornt system in black.
#55
I am not sure if the Lexus line is big enough for them to put serious $ into developing the rear. Other than us, Lexus is still viewed as a luxury line and the percentage of owners upgrading brakes is small. The number is probably even much smaller for those who would want to spend another 2k for a mostly cosmetic upgrade.
Anyway, congrats on the black. Just curious, what pads are you going with?
#56
#58
damn I really regret not going with the polished inners ....I know its like 1k more but it must look SOO much better with a bbk.
The inners do look hot.....but they dont come without their issues.....they are a you know what to clean. Flashgordon had his inners polished, and he just got the wheels back from having them changed to painted......he couldnt take the constant cleaning of the inners.
#59
#60
