heres my REAR BID BRAKE UPGRADE
#61
Forum Administrator
Originally Posted by lexforlife
gs oem rear rotor is 12.07 and solid , the supra tt rotor (which is what you have to use to mount these) are almost 13 in and are vented like the fronts for better heat disp..
So is the rotor you use for the rear in your setup the same as the front Supra TT rotor or the same as the rear Supra TT rotor?
Edit - great info here on the Supra TT weights for comparison
http://www.suprahardtopregistry.com/...uction/car.php
Stock brake pads (front) 5.00 lb Stock Supra TT brake pads (front - set of 4)
Stock brake rotors (front) 20.50 lb Stock brake rotors (front)
Stock brake rotor (rear) 14.00 lb Stock Supra TT brake rotor (rear)
Stock brake caliper (front) 15.00 lb Stock Supra TT brake caliper (front)
Stock brake caliper (rear) 6.00 lb Stock Supra TT brake caliper (rear)
vs weights I took myself on a UPS scale from my old Supra TT front brake setup
Supra front Rotor 19.65 (drilled / slotted)
Supra TT front caliper with EBC pad 16.45
#62
the rotor for the rear is from the supra tt rear ... all specs are equal to oem gs except the width because of venting and the overall dia.. bolt pattern and hubspacing for emgerncy brake parts are the same ...
dave i would highly recc this mod to anyone who has perf in mind and looks secondary... its a nice compliment to your front hands down
#64
Originally Posted by HKGS300
any update on the performance?
brake setup works like a charm.. i now find myself waiting for the last moment to brake and also find myself doing more 100 to 0 stops just because i like the smooth linear instant feel of the complete setup...
it feels like a brembo 4 wheel setup if they made one
#67
Originally Posted by Cypriot
Endless have good racing brake kit for rear.
332 mm and 4 spot.
332 mm and 4 spot.
yeah i hear ya bro and so does rotora and stop tech but why spend 4-6k dollars and a big brake kit like those which is tremdous overkill and does not stop any shorter or faster then a supra tt front back or supra tt front with ls430 rears ..
i mean my set up front to back is a hair under 2k for everything and depending how you buy the calipers can be in the 1500 -1700 range ...
if 700hp supra feel the tt brakes are more then adaquate for stopping power thats good enough for my little old 300+ hp machine
although one cant dispute the wow factor on a endless setup but it would take a whole lot of WOW for me to digest forking over 5k for that setup
#68
I will go up to 750 hp....this is reason.
#69
exclusive matchup
#73
Originally Posted by rominl
just to clarify, stoptech has no rear setup for the gs right now
the bracket is custom made out of asia.. it is made out of hardened composite steel just like the ones used by stoptech/rotora..
i totally agree with you jeff
i just dont buy the hype and to me it sounds like hype , i too have spoken with stop tech , rotora and brembo and they cannot tell me specifically what makes their system work in harmony and deliver proper bias while improving front braking... that would be magic in my book
Our kits maintain brake balance and are meant to go with stock rear calipers. Again we do this by selecting the right piston sizing. Most other companies do not have the ability to place in custom piston sizing for each specific platform. The piston sizing that is on a GS400 is not the same as the piston sizing for a Neon SRT-4
I saw that there was some comparison in regards to surface area of brake pads. The larger the pad the more heat capacity it has. Larger pads do not necessarily mean more brake torque. Please see this FAQ for more info. http://www.stoptech.com/faq/data/faq10.html
#74
Forum Administrator
Howard,
Since the current Stoptech front is designed to work in balance with the OEM rear GS brakes.... Does this mean you will be making a different front brake (or different piston size) to work in harmony with the new upcoming rear Stoptech brake?
#75
They are very strong and light..
