Strut Tower spacer/washer
The reinforcing ring on top ot the strut tower under the nuts.
Used as a spacer to raise the strut tower brace to clear the intake manifold.
Lexus part 53723-24010........$28 (dealer)
Toyota part 53723-24012........$13 (elmhurst)
Got a generic STB off ebay and it cleared the intake manifold by about 1/8". Added a set of the above for more clearance. Now I will add one more to the passenger side for more clearance over the IC piping.
yea i added those to mine's as well. according to some, i was suppose to use two extra spacers on top of the stock one already there. but i found if i did that, i wouldn't have enough stud thread to tighten the nut down. so i only used one extra on each side and took off the L emblem on the V8. Fits like a charm. didn't need the extra set.
nice job and good post. i used regular washers works great painted them black but i'll probally be picking up a couple of those also
These cars are not McPherson strut. Draw a free body diagram of the suspension forces, it will become evident that the forces through the strut tower are not that great as compared with a McPherson strut car. But, maybe I am missing something. I have been racing these cars on road courses for a couple of years and have yet to see a reason to install a brace like I did on the BMW.
Our cars are pretty rigid, so strut tower bars don't help as much. When I was still fixing up Hondas the chassis flexed a lot more, so the strut tower bars that tied into multiple points on the chassis (firewall or UCA bolts) helped a lot.
The Carbing stb comes with a master cylinder brace. I think that's a cool feature to have.
I haven't heard anyone mention a free body diagram since I took physics my freshman year in college. lol
It does as lots of people have said it affects the handling of the car.
As you said the force is mostly parallel to the shock, but you have to factor in that the strut towers have an angle towards each other and are not parallel with the ground, so while most of the forces would be going up and down, a small percentage of the force would be applied on the horizontal axis. Its not much but its enough to get a slight flex and the bar helps with that.
