New front stb clears engine cover
Old 06-11-05, 09:55 AM
  #106
chuckb
chuckb's Avatar
Originally Posted by GSing430
it's not shiny as the RVM blue but matted instead. you HAVE to take out the factory RING inorder to close the hood, those that have the EDFC will have to take off the rubber cover. it will stil touch the bracket but should be okay. without the ring, you can close the hood but it will still touch the lining of the hood. as for the any differance in performance, i didn't feel any. but it did what i had intended/hope it would do it that it prevented my EDFC from rotate freely. so i'm happy
thanks for the info. how bad does it rub the hood liner? do you have to actually push the hood harder to shut it now?
Old 06-11-05, 09:59 AM
  #107
HKGS300
HKGS300's Avatar
The bar slightly hits the hoodliner, this is because it has to clear the GS300 engine cover.
You do not need to push any harder to shut it, just close it like you did before.
Old 06-11-05, 10:02 AM
  #108
GSing430
GSing430's Avatar
with the oem ring on, you can't close the hood or even force it to close, w/out the ring, it's still touching for sure, i would say it's sitting against the padding pretty close, a tight fit more like it.
HKGS300
Glad you liked the strut brace... Post some pics
i won't be able to post any for a few days, my parent's computer is stone age to do anything.
Old 06-11-05, 10:43 AM
  #109
chuckb
chuckb's Avatar
does it leave an indent in the liner?
Old 06-11-05, 06:31 PM
  #110
rgarjr
rgarjr's Avatar
HKGS300
I just installed my STB and I left the OEM rings on there and the hood closes fine and my EDFC motors with the rubber covers have good clearance.
Old 06-11-05, 07:02 PM
  #111
HKGS300
HKGS300's Avatar
We want pics!!!
Btw ... what GS is yours? GS400? GS300???
Old 06-11-05, 07:03 PM
  #112
HKGS300
HKGS300's Avatar
Perhaps someone should make pics of the DSR strut brace install and post a DIY
Old 06-11-05, 07:14 PM
  #113
chuckb
chuckb's Avatar
Originally Posted by HKGS300
We want pics!!!
agreed
Old 06-11-05, 10:47 PM
  #114
GSing430
GSing430's Avatar
Do you have the CS? Because i have the Flex and i can't mount the brace w/out taking off the rubber piece. Maybe my brace that they sent might be different, but i can't close the hood, and i did try to force but it's not gonna happen unless i take off the liner.
Old 06-11-05, 10:58 PM
  #115
rgarjr
rgarjr's Avatar
I have a GS300 and have the Tein CS with the EDFC.
Old 06-11-05, 11:02 PM
  #116
GSing430
GSing430's Avatar
the CS sits lower than the Flex
Old 06-13-05, 02:19 AM
  #117
rominl
exclusive matchup
rominl's Avatar
the problem with the flex is that the strut tower center point sits quite a bit higher than the cs, that's why with the edfc it's a lot higher than the tein cs with the edfc. that's why it's hitting
but man, with the wings on and you can't put the stb on without denting the hood? that's kinda bad man. i think people should know that, otherwise some people might keep the ring on, put on the bar, and bam on the hood, dent it up......
so gsing430, what you gonna do now? take off the plastic cover on the edfc?
Old 06-13-05, 05:14 AM
  #118
chuckb
chuckb's Avatar
is there any need to have the oem rings on if the bases of the strut brace take their place?
Old 06-13-05, 05:22 AM
  #119
HKGS300
HKGS300's Avatar
I suggest to take the oem rings out. The strut bar mounts will be strong enough to act as a base for the strut top nuts.
Old 06-13-05, 06:34 AM
  #120
TXGS
TXGS's Avatar
BTW, I was told Friday that the braces for the DSR strut tower bar are primer blue. Has anyone received the DSR strut bar in the past two weeks?
Quick Reply: New front stb clears engine cover
