New front stb clears engine cover
#122
EV ftw!!!
Alex, can you comment on this:
Originally Posted by rominl
the problem with the flex is that the strut tower center point sits quite a bit higher than the cs, that's why with the edfc it's a lot higher than the tein cs with the edfc. that's why it's hitting
but man, with the wings on and you can't put the stb on without denting the hood? that's kinda bad man. i think people should know that, otherwise some people might keep the ring on, put on the bar, and bam on the hood, dent it up......
so gsing430, what you gonna do now? take off the plastic cover on the edfc?
#123
#124
Originally Posted by HKGS300
The above people all got their DSR strut brace recently ... and yes, the current batch has powdercoated blue mounts.
can you paint over powdercoat easily? I think I'm going to take mine to a paint shop and have the bases painted.
#126
exclusive matchup
Originally Posted by GSing430
it's mounted right now, the rubber piece is off and the ring is off. the edfc clears but the back side of it, facing the firewall, is touching neck to neck, Without the ring, you can close the hood, it just sits against the padding. but if you keep the ring, in you're pushing against the hood, and i don't recommend that. i have pix of it. but i'm away from home.
#127
Btw, what is the torque spec on the strut mount nuts?
#128
Originally Posted by chuckb
light blue on midnight pine =
Why not just powder coat the whole thing the color of your choice? Much more durable than paint, almost impossible to scratch. There are hundredds of colors now to choose from, including some that look like chrome or brass. You could match your cars color or its brightwork (chrome, gold kit, black pearl whatever you got)
#129
Originally Posted by JyGS430
I finally got mine yesterday, it is chromed w/ blue mounts. I hope it clears okay.
Btw, what is the torque spec on the strut mount bolts?
#130
exclusive matchup
Originally Posted by DetMich1
For TRD it's supposed to be something like 46 or 47 foot pounds. Seems like this should be about the same, after all, its the same nuts and bolts being tightened just a differnt bar spanning the strut towers.
#133
Master Thread Closer!!
