Results of spacers for big brake clearance?
Guys,
Any of you that have used spacers to add big brakes, how did the car drive afterwards?
Did you get increased tramlining afterwards?
What type of spacers did you use?
Did you get increased vibrations in the wheels?
Was it more difficult to turn the steering wheel?
Thanks,
Ryan
Thanks,
Ryan
i had 5mm spacers on the volks to make the rims more flush against the car, but i didnt like the spacers. It made the car feel less stable and caused vibrations at speeds over 65mph. I dont think i would use spacers again.
H&R 5mm spacers do. If you don't use a centered spacer, like the cheapo spacers at the auto parts stores for $10, then it will cause problems. I used the H&R 5mm spacers on a set of ADR Kasai's with the LS400 calipers and I didn't notice any problems or difference in the handling of the car.
more road imperfection are feel on steering wheels, no harder turns or another sensations. Only more road imperfection can be feelig on stering wheel. perhaps is for added unsprung weight (my 22 mm spacers are from steel not from alu for durability)
Car brakes MUCH MUCH better than before.
Jerry
Jerry
Originally Posted by Neo
Really? Is this new? I know a few people with H&R 5mm ones and they don't come with the lip to mount the wheels.
The One
Originally Posted by jeremyp111
The H&R 5mm spacers are centered on the bore of the hub and also leave enough of the stock hub exposed for a hub centric ring to fit. A little grease on the ring helps. The most important thing is for the spacer to be centered on the hub to keep the weight balanced. Cheap spacers that don't sit centered will cause vibrations because it won't be balanced. Most aftermarket wheels are lug centric so a hub lip isn't that important.
I agree that weight distribution is important but I think the lip is. I personally will not buy a rim that cannot be made hub-centric, either as part of the design or via a ring, with the former being preferred. Without that lip on the hub, the rim hub-centricity becomes useless. The star technique to tighten lugs helps but I would still rather have it centered physically. Of course, this is just my preference.
Fitting spacers has to be done with some regard for the wheel offset, despite some who say it dont matter, adding track width with spacers (in effect reducing the wheel offset) alters the steering/handling.
5mm may not sound like a lot but if your flash wheels are already reduced in offset (less than 50mm) then adding spacers will be askng for trouble.
Fitting spacers or wheels which do not have concentric location is even worse! I have seen several sets of alloys fitted to cars with either no spigot rings or simply oversize, no way on earth will these wheels run true on the hub.
Wheel spacers
Originally Posted by SC400T
Guys,
Thanks,
Ryan
Thanks,
Ryan
Originally Posted by stevechumo
You're right. After using the spacers, the car has to be realigned. It's because the SC has a differential which makes the wheels tilted in when going straight and tilted out when cornering.
The steering design includes an angle called "scrub radius" changes in the wheel offset also changes the scrub radius angle, this will alter the way the car steers and handles. Alignment cannot cure this.
The suspension and steering are designed to work in unison to create the handling characteristics of the car, any deviation from the factory settings causes changes in the handling. As the body rolls in cornering the suspension/steering angles change, it is this design which attempts to keep the wheel in the best position during this period hence the wheels lean in/out during cornering and body roll.
Incidentally, the in-board rear differential which is fixed to the rear axle cage, plays no part in the suspension geometry.
