just replaced front lower ball joints
Old 03-21-05, 09:04 PM
  #31
rominl
exclusive matchup
rominl's Avatar
Originally Posted by LEXUS_KID
Does TOMS make tie rods for the GS or are you buy OEm ones?
huh?! tie rods? what tie rods?
Old 03-22-05, 04:07 PM
  #32
sockfocks
sockfocks's Avatar
Default easy
this is an easy job, i did it myself with NO power tools...just the balljoint puller from autozone for 10 bucks. I did have an 18in breaker bar with 1/2in drive...used a 1/2 to 3/8 drive adapter to be able to use my 3/8 drive sockets with the breaker bar. Nothing hard at all...and my car has some mileage on it, trust me...the ball joints need to be inspected and replaced, it seems they dont last long and i never would've suspected it until it was too late...thanks to searching cl i found that ppls ball joints were coming apart....i'm lucky it didnt happen to me..my ball joint had about an 1in of up and down play...:O got a new one from the dealer for 104.00 i could've saved some money looks like from the posts i've read...but i couldnt wait..the car was wandering all over the road and needed to be fixed asap.
Old 03-22-05, 06:15 PM
  #33
dmodstl
dmodstl's Avatar
Post
Definetly recommend replacing lower ball joints. It is more preventative, but for your safety it is a small price to pay.
At around 80,000mi. I reported to a local Lexus dealer the aforementioned 'play' in the steering and uncharacteristic clicking noises. We took the car for a test drive at a commercial parking lot-performing figure 8's, high speeds and sharp turns,...... I was informed it was nothing to be concerned with and that the extremely cold weather we had could be contributing to these things. No less than three days later my lower front driver's side ball joint completely failed. Fortunately for me, I was pulling out of my driveway doing 2mph. Lexus did step up to the plate and fixed everything, but it could have been a lot worse.
It seems I am not the only one to have this problem.
Lower Ball Joint Failure
BTW. (A newbie who knows how to use the search function.........how novel?!)
Old 07-11-05, 09:30 PM
  #34
ILOVEGIRLS
ILOVEGIRLS's Avatar
so when you press out the lower ball joint you push it upwards? how do you press it back in when there is the screw on the other side?
Old 07-11-05, 09:57 PM
  #35
lexforlife
lexforlife's Avatar
once assembly is removed , place new unit in correct position and thread nut from bottom and trq down thats it
Old 07-12-05, 03:33 AM
  #36
DrewGS350
DrewGS350's Avatar
Excellent post! I am not a big mechanic but this is something I would consider doing myself. Only have 11,237 on my 03 and will remain the same for a while.
Old 07-12-05, 07:13 AM
  #37
corkycal
corkycal's Avatar
ed,
when you replaced your tie rods, was it the outter or inner or both? i think the outter is connected to the ball joint??
we still need a diy guide for this project..hint..ed
Old 07-12-05, 07:51 AM
  #38
lexforlife
lexforlife's Avatar
Originally Posted by corkycal
ed,
calvin it was the outer , the inner do not absorb as much shock as the outrer does
Old 07-12-05, 07:56 AM
  #39
corkycal
corkycal's Avatar
ed,
i found this thread with pictures that's pretty good. i got stuck on step #11 where he said to mark the tie rod end, i don't know why but maybe you can explain?
https://www.clublexus.com/forums/sho...wer+ball+joint
Old 07-12-05, 08:00 AM
  #40
lexforlife
lexforlife's Avatar
if you are replacing the outer tie rod ends you will need to have a new alignment done , marking it will give you a pretty good chance of putting your toe back to where it was so at least you can drive to get a alignment done , remember your outer tie rods set inner and outer toe
Old 07-12-05, 08:03 AM
  #41
corkycal
corkycal's Avatar
thanks ed, i understand now..did you get your parts from carson toyota?
Old 07-12-05, 08:25 AM
  #42
SoCalSC4
SoCalSC4's Avatar
This thread has inspired me to replace my lower ball joints... and I'm replacing the front "caster arms," too.
These are the control arms which locate the suspension fore/aft.- the bushings deteriorate, contributing to the GS front tire wear issue. Then off to Shoreline Motoring for a four-wheel alignment...
Old 07-12-05, 09:11 AM
  #43
sputniknyc
sputniknyc's Avatar
Default parts list?
ball joints left and right
tie rod left and right
outter tie rod?
bushing?
upper mounts?
I will need a full part list to get mine done. Please advise.
Old 07-12-05, 05:04 PM
  #44
sputniknyc
sputniknyc's Avatar
low priced tie rods.
Anyone ever use these or should I stick to OEM Lexus?
http://oem.thepartsbin.com/parts/the...rt=Tie+Rod+End
also
http://www.olyonline.com/Lexus/lexus_catalog.htm
anyone have pricing on OEM lexus tie rods?
GROUPBUY!!!!!
Old 07-12-05, 07:37 PM
  #45
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
Very interesting review of the tie rods... Maybe i should do this in the near future?
sputniknyc--- I assume that the website you posted for the tie rods is for 98-2000 Gs 400 models... Just curious and the price seems to be pretty decent Also saw the right up from corkyal and very inforamative. My car only has 54,900 miles and I'm about to put 20's on.. So this may be a good idea to do?
Tony
Quick Reply: just replaced front lower ball joints
