Tein CS questions.. Need HELP!!
Any of you guys know how to check the TEIN CS if they are bad or not. I've been hearing weird noises comming from my rear suspension. Also when i'm trying to adjust the dampering on my TEINS i can go over 20 turns. I thought there's only 16 turns. Something is weird. Please help.. Is it time for me to move on to HKS coilovers?
Tommy
Tommy
yeah as long as you tighten it till lock as stiffest that's good. and don't go over 16
anyway, if you didn't abuse the tein cs i don't see how it will go bad so soon, mine is still good. are you sure it's none of the bushings or so? my sway bar bushings were all dried out causing noise
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Good advice, Henry! My sway bar bushings (possibly other bushings too) were very dry not long ago-terrible squeaking sounds drove me nuts. Took it to a local shop, put it on the lift and greased the bushings-no more noise at all!
My Tein CS have about 23k miles on them with NO noise or problems at all.
Originally Posted by Lexus GS3
Good point Henry. I'll check up the bushings and the bump stop this weekend. The noise is driving me NUTS.
Kinda makes me wanna go back to shock/spring setup.
Tommy
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Tommy
